#61
70 GTO
455 .030 11.5 to 1 compression Induction- E-heads, 320 cfm, 1050 dominator on alcohol Trans- tubro 400, 9" hughes 5000 convertor Rear gear- 8 3/4 Chrys w/4.86 Tires- 31x14x15 Hoosiers slicks Fiberglass front end, doors, trunk and bumpers Lexan windows Best ET/MPH 1/8) 6.75@99.75 Best 60' time- 1.42 |
#62
1968 Firebird
474 e-heads victor 1050 Dom turbo 400 3.89 gear 14x31 3115 w/me in it (not for long) Best 9.71 @ 138. |
#63
1968 Firebird 350 HO Convertible. Raced at the Pure Stock Muscle Car Drag Races.
Automatic 3.55 LS F70/14 Goodyear Polyglass Tires Log Manifolds Pypes Exhaust 2 1/2 Mandrel X Transverse system Dyno: 330 hp and 395 torque in street trim 3,900 pounds with driver. 2.030 60 ft 5.781 330 8.908 1/8th mile 13.93 @ 97.76 quarter mile
1979 Pontiac Trans Am - W72 400 - 4speed - WS6 - Heritage Brown - Air Conditioning |
#64
1969 GTO Judge clone
Street legal (and driven) full interior (including console) 69 goat Judge clone in Hugger Orange or as Indian fans call it Carousel Red.
3925 lbs w/driver 13.3:1 540 CID PONTIAC N/A - NO power adders! IA II block, Forged crank, Forged H-beam rods SD ported Edelbrock wide ports flowing 370+ (non heart shape chamber) T&D offset shaft rocker system. SD massaged Victor intake. Pro Systems 1050 Dominator. Ultradyne solid roller custom SD spec .730 lift Doug's headers Jet Hot coated 1 7/8" primary 3.5" collector (yeah I know they're too small - I'm working on that!) MSD 6AL w/2 step Reverse manual TH-350 w/brake. Moser 12 bolt 3.72 boxed upper arms, SSM slappers, otherwise bone stock 30" x 10.5" Hoosier slicks Best time to date: 60' - 1.435 330' - 4.118 1/8 - 6.343 MPH - 110.11 1000' - 8.280 1/4 - 9.930 MPH - 137.52 Notes: Left @ 3200 on brake (usual 4800). Had to pedal on that pass - got out of the groove due to violent launch! Just figured out after 15 passes that this 540 likes to rev to at least 7200. Dave Bisschop told me it would. Tossed the 6500 pill in the garbage! Not even turning 6000 through lights so obviously, I will be swapping the 3.72 gears for 4.10 and possibly even 4.3 and will run with open headers. I fully expect to be posting at least a 9.7X pass by next week. |
#65
1987 Firebird, IHRA No box, 1.43 60" 10.25 @133
#66
1974 Ventura 3350#
462 CID/#13 heads/4150 HP1000/Victor intake (N/A) TH400/ATI 4200 stall/3.90 gear 275/60 Drag Radial/Cal Tracs/Split mono leaf Street/Strip (Tagged/Insured) 3" exhaust (Today @ Cecil Co.) 10.38 @ 128.89 MPH 1.467 60'
74 Ventura 462/#13 heads/3350# 10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured |
#67
FAST
JOHN HILL
1967 FIREBIRD 2900 LB 505 CI ia 2 365 CFM HIGH PORTS GLIDE 4.30 GEARS 33-10.5 TIRES 5.87 AT 117 1/8 AT KANAWHA VALLEY 1.27 60 FT 9.31 AT 145 1/4 AT PITTSBURG 1.31 60FT 1050 DOM VICTOR NEXT YEAR G-RAM 2 850S LARGER CAM HOPING HIGH 8S |
#68
69 Firebird-3465 lbs
Stock suspension (Cal-Tracs) Turbo-400/ PTC converter 12-bolt 3.73 gears 325/50/15 Mickey Thompson drag radials 477 IAII Procharger F-2 E-heads Victor intake 850 CSU carb (Blow-thru) Best E.T./MPH so far 60': 1.270 1/8-mile: 5.52 @ 127.39 1/4-mile: 8.601 @ 159.83
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
#69
Phucking weak!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#70
65 gto conv tri power 4 speed 3630lbs 6.929 99.88 8th 10.98 123.79 quarter 4.10 gear10-1motor 440ci bycvms and a fun ride
#71
Ken,
Just cause I know how to turn left and right you ain't leaving me out... 68 Firebird 366, T-2 w/ holley750 #17 heads Headman 1.75's M-20 3.08 26.7 od rear Goodyear Blue Streaks 1:58 Lap time on a 2.6 mile road course. Around 120+ mph so far on the back stretch, I'll break 140 eventually A great lap time there should be in the 1:40's 1:58 was my first offical Solo lap time, all I wanted was to break the 2:00 mark. I'll post times as I improve. |
#72
Update from PONTIAC HEAVEN XI
65GTO 3550lbs
497cid 12.9:1 110octane No Power Adder Factory - Block/Crank/D-ports Victor/1050 Dominator T400/9.5"4200stall/3.91/30"x9"Radial Slick Footbrake/1470altitude/2800 D.A. 1.41 60ft 6.45@104.97 1/8th 10.25@127.12
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
#73
69 GTO-3650 lbs
Ladder bar suspension Turbo-400/ PTC converter Fab 9" 4.29 gears 33x16x15 Hoosier slick 537 IAI NOS fogger and Big shot plate total 475 hit E-heads Victor intake 1250 Carb Best E.T./MPH so far 60': 1.240 1/4-mile: 8.521 @ 160.65
6.98 @ 199mph 4.53 @ 164mph |
#74
69 Firebird
3480lbs 461 kre 85cc 850 aed dp th400 10 bolt 3.90 stock suspension 28x10.5 x15 m/t slicks 3" exhaust, x-pipe, Dynomax super turbos taxed and insured 1.62 60ft 11.27 et 119 mph Rick Denny
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
#75
Ok here goes - 2008 GTO -
60' 1.07 best ET - 6.93 best MPH 201 weight 2500# 525cid with twin 88mm tubos powerglide 4.70 and 160 mph at the 1/8th |
#77
best so far
1969 Firebird
3.55 gears 3640 w/me in it 1.87 60 ft.(new best) 12.36 1/4 mile 112mph 5spd TKO...6300 rpm in 3rd gear thru the traps 428 .40 over R/A II heads 800 holley D/P mickey thompson E/T streets 20psi
434 CI TKO600RR 1969 Carousel Red RAII Heads...Pump gas 400+hp/450+tq at the wheels...life is good! |
#78
1968 firebird
3.23 gears 3600 # with me 1.99 60 ft 12.62@110.34 turbo 350 2500 stall 417 ci 4.185" by 3.79" #12 heads flow 280 cfm hr 230/236 .565/.570 rpm holley 870 hooker 1-5/8 pypes 2-1/2" x pipe crossflow 235/60/15 et streets
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
#79
Finally got some times to post. Quickest run from this past weekend of testing and racing was:
1.413 60 ft. 6.655 1/8 10.588 1/4 125.283 mph 1978 Trans Am. All steel. 3330 lbs race weight. Track only. Pump gas 464 cid with KRE d-ports. 9 inch rear with spool and 3.89 gears. 30 x 9 Hoosier radial slicks on 10" wheels. Only launching at 3400 with trans brake so there are better times to be had. I will need to get some good adjustable rear shocks so I can leave harder without spinning.
www.hobracing.com |
#80
67 Firebird 1.45 60' 10.47 @ 127 mph Still new at this racing a car with HP Last car was high 12s.
