On my 68 GTO the rust is way too heavy to find any #s on the axle. I took took the rear end cover off and was told that the #s would be on the gears. The #s on the gear are 41 14 GM then reading across it appears to be stamped backwards 98 BA. Hope this helps to find my gear ratio. I'm curious as hell.
"You must create your own demand."-John Bonham Dave Degard 1968 GTO Cameo Ivory w/69 400 YD motor w/46 heads http://photobucket.com/harleycops68GTO |
41 divided by 14 will give you your ratio. I don't have a calculator handy.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
2.93, standard ratio for a 68 GTO with auto and AC
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Thanks guys.
From what i was told on here most 68-GTOs with air came with a 3.55.
68 GTO
base engine (HO engine) AC auto = 2.93 (3.23) auto no A/C = 3.36 (3.55) stick A/C = 3.23 (same) Stick no A/C = 3.55 (same) HO cars had following
I agree, I've had a couple auto/AC cars and both had the original 2.93 rears.
Mike |
In 69 the Auto A/C with the base engine was changed to 3.23 and during the model run (unannounced) they seem to have switched to 3.55 gears on Non A/C auto base engines.
Pretty good guess aye? Now you need to find out whats in the 72 Old's.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
For what we're doing is that enuff?
I just happen to have a TA rear end out back along with a spare posi case and 3.23 gears. Both new in box.
How wide is your GTO axle(backing plate to bkg plt)? All we would have to do is R & I the control arm and spring mounting brackets.
