69 GTO Endura bumper attachments
Does anyone have any of the brackets that attach the endura bumper to the body. I have posted in the "Parts Wanted" section but thought I'd try here too.
I need: front bumper stabilizer part# 9791639 stool, tilt drive torsion bar part# 9791691 any help appriciated Thanx |
Give Bethels Goat farm a call.
Send it! It’s going home on a trailer. |
Hi nh68gto
Do you have a phone # email or website for Bethels Goat farm? Thanx for the help |
I have a set of 68-69 GTO non-hideaway endura bumper brackets and stabilizer brackets. I converted to hideaways. Can't seem to find any part numbers but can supply pictures if you still need them.
I'm confused. I converted from non-hideaway to hideaway (68 GTO) and had no problems with the bumper brackets. Can somebody post a pic of the problem area?
68 GTO ragtop 91 T/A 69 XKE |
pnswann1 pictures would be helpful as I'm dealing with a mechanic doing the job in another location. Thanx
fyrebird68 unfortunately can get any pictures of problem for a week or so til I get back to town |
the 9791691 is the bracket that mounts to the inside of the endura corner to mount the hideaway flip brackets to. I'm pretty sure I've seen those repopped. I may have one of those laying around, I'll check my piles. Later, Dennis |
gto4evr
From your description I now understand that the only thing holding the endura bumper in place is the two "front bumper to frame bars" part # 9790316. Right?? The two front bumper stabilizer/brackets # 9791639 are attached to the bumper and only butt up to the rad support via rubber cushion providing support but not solid attachment. right?? The torsion drive bar is only used for hideaway headlights. So I don't need that. Mechanic saw all these bolts/attachments on bumper and thought I needed both pieces. Also talked with a guy at a car show in Radium Hot Springs yesterday and he confirmed the above - hope you agree with my understanding. Hard doing the work away from the car and my manual but I'll get back to both in Calgary tomorrow. Thanx for your help |
Rick, you got it! those stabilizer brackets are supposed to help stop the ends of the endura from chattering around on the fenders since there's no actual connection between the two. Since the fender is bolted to the rad support, those stabilizer brackets pinched up into the rad support help stop the endura from bouncing around. The whole front end floats on the rad support, the endura is mounted directly to the frame via the frame brackets. Since the body flexes, that nose will pull away from the fenders when you jack it up. Make sure when you're aligning the nose, you do it on the ground with the engine in place. If you do it up in the air, the endura will crush into the fender when you drop the car. Even with new body and rad support mounts you'll still see up to a 3/8" gap open up when you jack it. Later, Dennis |
Thanx gto4evr
That looks like my problem is solved, probably don't even have to go to Calgary now to check it out, but I really want to see how the bumper alignments going. Think you helped me about a year ago with a reverse switch problem Thanx again for being so helpful to a novice goat owner. Rick T. |
all the top suppliers sell your endura end mounts, Year one & Ames should most definatley have them. The other Pair are very hard to find with the rubbers still intact. i may have a set but the rubbers are gone I do have a NOS set im using on my Judge when i figure out just what exactly they do.... they always seem to be in the way
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
for future reference here are endura hidden headlight brackets and a picture of standard brackets
the one with the angle welded to it is the hidden headlight bracket
Greg Reid Palmetto, Georgia |
here's the bracket minus the rubber. the rubber was a cushion on the end that wraps around the the top and sides of the folded edge, (on the left of the picture) the hole in the end of it was for a rubber tit on the bumper that popped through the hole to hold it in place
these are the pics of the frame brackets 9790316 and 9790317 (standard non hideaway part numbers), not the 1691 Rick originally asked about - that one is the W shaped bracket that goes on the inside edge for mounting hideaway buckets to the nose. Still great ref pics for the guy out there thinking of adding hideaways to his car!
no problem! you know where to find me when it's question time (and I SHOULD be outside working on these damn cars, not on a computer talking about them!) Later, Dennis |
Jeff |
Jeff, thanks for the plug!
Scott -- I've NEVER seen these repop, got a part number? I just crawled through the PY manual twice and don't see them. I DO see the 71/72 versions (PYF28) but those do not fit on the 69 stabilizers. |
