Old 08-08-2008, 11:32 AM
ponchorob ponchorob is offline
Default et improvment by changing heads only!!
hi guys! i thought it would be interesting what you other guys gained by changing heads only!-all other things remained the same !! carb & intake manifold change is allowed when also tested on the original combo!!
Old 08-08-2008, 11:39 AM
PONTIAC DUDE's Avatar
Thumbs up
I have a bunch of info on a head change from a 308cfm E-head (88cc) to a set of out of the box (90cc), 360cfm at my .650 cam lift!!! CV-1's in my 76 T/A. Pump gas, hydraulic roller. It's located here. http://www.pontiaczone.com/forum/showthread.php?t=22196
You can sort thru all the negative crap and hassle then form your own opinions. I'm happy and not looking back.
Only change was the heads and worth .3/.4 depending on the weather conditions taken into account.
Old 08-08-2008, 11:59 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Do not forget, a head change also may dictate a compression change.
Old 08-08-2008, 01:32 PM
Ron H's Avatar
Ron H Ron H is offline
I picked up 75 RWHP with no changes except from 230ish ported 6x heads to 310 KRE D ports.
68 Firebird
Are you running with the wind or breaking it?
Old 08-08-2008, 04:12 PM
455firebird1969's Avatar
Default .5 second
#62 's to Edelbrock's = five tenths
Old 08-08-2008, 04:49 PM
66bonne's Avatar
66bonne 66bonne is offline
Went from a set of mildly ported 6-8Xs to out of the box KREs [260] cfm and picked up about one half second.
Jim
Old 08-08-2008, 05:25 PM
David Holmberg's Avatar
I picked up 1 second and 10 mph going from a set of stock 51 heads to a set of ported 6x's. With no other changes.
Old 08-08-2008, 07:53 PM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
Changed from 265 cfm #62 D-ports and a Warrior to High Ports and a Victor. Same carb, same cam, same exhaust system, but with round port headers. Compression went from 10.2:1 to 11.3:1 with the chamber size difference. Still on pump gas though.
Previous best - 11.45 @ 116
New best - 10.59 @ 124.5
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 08-10-2008, 12:47 PM
70judgeconv 70judgeconv is offline
I went from 12.10's to 11.50's changing from kre poted 248cfm #96's to 310 cfm kre d ports. solid flatt tappet cam at 3995lbs. this is a street car driven 140 miles to the track.
Old 08-11-2008, 08:34 PM
Probird's Avatar
Probird Probird is offline
Changed from ported ram air 4's to ported E-heads. Went from a best of 6.58 in the 1/8th to a best so far of 6.10.
