68 GTO frame VIN and rear end ID
I pulled the body off one of my parts cars. I don't remember where to look for the frame VIN to see if it was the original frame, and also I can't find a two letter code stamped in the axle tube. Any help is appreciated.
Here is a good post with pictures:
http://forums.maxperformanceinc.com/...e+vin+location They can be very small, stamped lightly, and hard to spot. |
This will make it easier
http://forums.maxperformanceinc.com/...3&postcount=15 For your differential numbers, look on the rear facing side of the axle. My marks are stamped on the passenger side tube |
68gtoMN,
That's interesting. How do you go about linking a single post?
Greg Reid Palmetto, Georgia |
It looks like code SE is stamped in the passenger side axle tube. Doesn't look like a Pontiac rear. But what is it?
Click on the post number in the upper right corner of any post. Then copy/past the url. Wahla
By the way...It's definitely not a Pontiac rear end. I think it's an Olds rear. Here's a site that will help you though... http://oldsmobility.com/reardiffs.htm Check out the related links near the bottom of the page too.
Thanks everyone for the info.
If there was a VIN on this frame, it's gone now due to some heavy rust. Without any visible numbers, is there any way to identify a GTO frame from a Cutlass or Chevelle frame?
