Milling 6x Heads
I have a set of JBP Street Strip 6x heads 9.5 to 1 on a 455 with trw forged pistons.
Is it possible to mill these heads down to obtain 12:1 and run race gas or is that too much material being removed? I'm sure the manifold will need to be matched as well. |
I thought you guys were too CHEAP to run race gas!!LOL
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot Last edited by 70 lucerne lemans; 07-29-2008 at 12:14 PM. |
I'm just looking into it.... just cause I don't have enough money to buy 3 SETS of rear wheels doesn't mean I'm cheap... LOL
No, the deck surface will be way to thin. Its time for different pistons to get 12 to 1.
Seriously,I've seen some good deals on used Eheads lately.Another option is I have a set of 62's (72 cc)that would get your compression up that we could do a Jim Hand port job on and put in your valves and springs.
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot |
not to mention a new torque convertor. I think I'd rather stick $3k to get another car. You know, I guess I am cheap. I was just trying to see what power I can get out of my existing parts without blowing a load of cash. |
I think a bigger cam and some more tuning will get you low 11's.Something I think you really need to do is make a cold air intake,your hood is pretty close to the carb too.
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot Last edited by 70 lucerne lemans; 07-29-2008 at 01:49 PM. |
Yea, my car could benefit from a 290B and a cowl hood.
The quick answer is...NO.
I had a pair of 6X heads on a .030" overbored 455. They measured up at 98cc and with all other parameters considered, produced 9.06:1 CR. I had them cut .060" which brought the chambers down to 86cc, producing a 10.12:1 CR. The most CR I think you can safely get out of a 6X head on a 455 is going to be around 10.5:1 using flat-top pistons.
i have same deal here, pistons,chambers,ex ports,valves all thermal coated, 260cnc 6x heads, i want to mill to 86-87cc for 10.00:1 area with my Ross 2vr FT's and i am at sea level basically, 92octane is what i can get, the cam i have is a hyd roller 236-244 at .050 289-305 advertised lift is .602in .607ex timing at .050 is ivo-10 ivc-44 evo-58 evc-6 with a 112lsa installed at 108, will this cam work with that high of scr? sorry to jack the thread but i have been meaning to ask for a while, is there a better hyd roller cam?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
i saw a pair of 6x heads that were whacked 120
the person who was using them had no problems, but that was on a 400 at the time i have heard of a few other people whacking 100 off them too they are pretty thick heads |
i have cut .100 off on several different castings including the 6x4s. never a problem yet but that doesn't mean there could be a thin spot in a particular head. the valley pan will have to be trimmed if you cut an excessive amount off.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
just a little hi-jack. has anyone here milled a head .100 or more in a high compression and high rpm application?
69 GTO 11:66@114.17 all balls no bottle 406 d-port iron heads 3700lbs all steel |
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
i did not mention in the other post, it is better to cut the intake side of the head when milling the deck, rather than cut the intake for alignment purposes.
When I had the 77 SE T/A - 455 6X it had 9.5-1 comp. according to the previous owner.
Pulled pretty strong and never skipped a beat on pump gas . The T/A is being restored as we speak by the current owner.
The Bandit Rules - Make mine with a SD-455 Engine . Last edited by Wareagle; 08-01-2008 at 04:29 PM. |
I have some 6X-4's milled to 81cc For Sale in the Perf. parts section of PY. They were milled by a shop in OH,(deck and intake). Just in case you are interested.
thepontiacman@yahoo.com
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
j.c.
cast iron, yes. would you mind giving me a few details of the builds. you can pm me if you wish. thanks, bob
