Early Model Year Engine Codes
I'm trying to figure out what would be the correct engine codes for my 1970 GTO. The car was an early production vehicle that left the factory around Sept 1969. It should have a WT code block in it. The block would have been cast in 1969, so would the year digit by the distributor be a 9 or a 0? What about he casting number, early 1970 or late 1969? The codes for 69 GTO and 70 GTO 400's are both WT, how do you tell them apart? Simply by the production date? Could a late production 1969 GTO and an early production 1970 GTO have the same block in them?
Thanks, Jason
1977 Trans Am 400/4spd 1972 LeMans 400 Sport 1970 GTO 400/3spd 1965 GTO 4brl/4spd Hi, my name is Jason . . . and I'm a Pontiholic! |
Your block would have had a code like G289 or H099 or I019, something like that. And, a block produced after May '69 would have been casting 9799914. EUN would tell the story on the block further.
The 1970 has its own casting number 9799914. (1969 was 9790071) The '70 WT block also has a large "70" next to the distributor, in addition to the casting date.
I have a '70 four speed built the third week of Sept. 1969 and the block casting date is H149, which is 8/14/69. The '70 has four engine mount holes, while the '69 has two. They also started casting the "400" on the sides of the block in 1970. |
Aut viam inveniam aut faciam 1971 Trans Am 455HO M22; Cameo White / Blue 1971 GTO Convertible 455 M40; Starlight Black / Black |
