Old 06-21-2008, 02:22 PM
Cammer-6 Cammer-6 is offline
maybe he traded it for 3 repops,send you one,he keeps 2.
Old 06-21-2008, 03:36 PM
69FIREBIRDMAN 69FIREBIRDMAN is offline
i wonder how you would feel if this happened to you and i came back with a reply like that?
Old 06-21-2008, 05:27 PM
weranc55's Avatar
weranc55 weranc55 is offline
That sucks. Dont know anyone in MN. I was actually going to bid on that hood. Hope you get your hood or your money back.
Old 06-21-2008, 06:52 PM
tom s tom s is offline
first issue,not sure what hood latch I have but the hole in the hood is about 1/16 in too narrow I THINK.Im going to let my body man figure it out will let the board know what he finds.Tom
Old 06-21-2008, 06:54 PM
THEY PROBABLY USED DYNACORNS 67 STEEL FRAME
Old 06-22-2008, 11:00 PM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
I was wondering if they would make that mistake. The 67 is absolutely different from the 69. I have seen guys re-skin real 69 T/A hoods where the understructure had been rotted out. Many guys are not aware that the understructure is not the same from 67-69.
Good luck on the recovery of a hood or your cash 69Firebirdman. I remember hearing that last name "Tuttle" being bantered around a number of years back and it was nothing good. Maybe in the Chevy world? I have no idea about the first name or state however.
Old 06-23-2008, 10:20 AM
thanks.
Old 06-24-2008, 08:54 PM
John Haley's Avatar
John Haley John Haley is offline
Angry WHAT ??????????
I just had my kid drive all the way to get this hood from the guy Terry bought it from on EBAY. It is NOT AN ORIGINAL 69 T/A hood. It is a re-pop. The hood latch catch is the wrong one. The frame is not cut out to fit the RamAir pan. The edges where the hood meets the fender is not as sharp as it should be, it is very rounded compared to the original that I have on my car. The spot welds are not right either. The center ridge is way too sharp and has a crease just below ridge instead of rounded area going up to center ridge. The beak also looks wrong, low, short, just odd looking compared to my original.
Old 06-25-2008, 12:37 PM
John Haley's Avatar
The shape of the scoops at the back of the hood is wrong also. I think what these reproduction T/A hoods need is at least 1/4"-1/2"skin of bondo on the whole hood to re-shape the contours. I do not think that the value of a real 69 T/A hood would be affected by these repro's.
Old 06-25-2008, 12:50 PM
steve v's Avatar
steve v steve v is offline
I wonder if this was a first run or protoype repro hood? Did the seller say how or where he got it from? Can you post some pics of the areas in question with your original hood pics as a reference?
Old 06-25-2008, 03:09 PM
John Haley's Avatar
Frame not cut on re-pro.
Original hood with frame cut for ram air pan
Old 06-25-2008, 03:14 PM
John Haley's Avatar
Original hood beak
Repro hood beak
Old 06-25-2008, 03:18 PM
John Haley's Avatar
Original hood, scoops at rear are still above center by about 1/4" to 3/8"
Repop, scoops are almost level with center of hood
Old 06-25-2008, 04:06 PM
weranc55's Avatar
So did you guys get the money back for the hood?
Old 06-25-2008, 04:48 PM
John Haley's Avatar
Original Beak and hood latch catch
Re-pro.
Front seam spot welds on orig. hood
Front seam spot welds on re-pop
Wrong shape at scoops contour ends on repop about 1" short of front of scoop
Orig. hood scoop contour, goes to front edge of scoop hole
Old 06-25-2008, 04:58 PM
John Haley's Avatar
Terry is working on it, The guy said he would give his money back but as far as I know has not contacted Terry today.
Old 06-25-2008, 05:22 PM
John Haley's Avatar
edge of repop hood rounded
Edge of orig. hood
  #38
Old 06-25-2008, 08:16 PM
Good review
Lets hope that this was a pre production piece that should have been headed for the dumpster.
  #39
Old 06-25-2008, 10:26 PM
Great info and pics John. Are you certain that this is not an original re-skinned hood? I know that you are "dialed in" on 69 T/A hoods. The reason I ask is that the top skin does look like it has been around for a while. Additionally, when many guys re-skin these original hoods, they peel the sides and front back to separate the inner and outer structure. This would explain the loss of the sharp edges and improper spot welds. Many people were not aware that the 67 understructure is different from the 68-69 and I know of a few hoods that were reskinned with the wrong understructure. Believe me, I am in no way doubting the inferiority of the repro. I just thought that this one looks a little aged and the repros just came out.
  #40
Old 06-25-2008, 10:36 PM
that hood looks nothing like the one I bought.If I go up to the body shop on the 3rd I will take pics.Tom
