Old 06-05-2008, 03:27 PM
MikeCio1's Avatar
MikeCio1 MikeCio1 is offline
Default Door lock rod holders
Does anyone know where I can get these? The are the plastic channels that clip to the inside of the door that hold the lock rod.
I am trying to post a pic but it keeps failing. So here is a link to my kodak gallery.
http://www.kodakgallery.com/I.jsp?c=...localeid=en_US
Pics 2 3 & 4
I thought PY had them under item RPI327 the description matched, but the item I got wasnt even close.
Mike
1970
LeMans Sport Convertible
www.fquick.com/mikecio1
http://www.facebook.com/MikeCio1
Old 06-05-2008, 03:41 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
If you are referring to those little white plastic deals I think they are being reproduced now. I saw them in the new Original Parts Group catalog (C240479). I'm sure the other vendors have them too.
Old 06-05-2008, 04:07 PM
MikeCio1's Avatar
I used that number on thier web site with negative results
Mike
1970
Old 06-05-2008, 05:13 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Mike, do you have a picture of what you received? I agree, from the description, RPI327 should have been a match. Ames PN is F109 for a similar description (no picture, though). I'll look at my doors to see if they match yours.
Old 06-06-2008, 12:19 PM
gto4evr gto4evr is offline
Mike,
I've probably got a few of these lock rod setups laying around. I didn't think you could replace the plastic, aren't the rods bent after the plastic slides are installed? Been awhile since I looked at them. do you need both sides or just one lock rod setup?
Later,
Dennis
Old 06-06-2008, 05:12 PM
MikeCio1's Avatar
I would think they would come out with a replacment clip since they get brittle after 30+ years. PM me if you have something that will work.
Mike
1970
Old 06-07-2008, 11:11 AM
Ron Landis's Avatar
Wink I've got a few...
entire mechanisms if you need them. Doesn't look to me as if the clips can be removed. Ron
Old 06-09-2008, 07:04 PM
MikeCio1's Avatar
Your right about the clips not being able to be removed I was just hoping they had an aftermarket solution. The part PY sent me is about a tri angle shaped piece of plastic an inch long 1/2 inch wide flat with a circular indent on the point end and a square indent on the wide end. I wwill try to post a pic but my cam wont load.
Mike
1970
