67 TH350 Console in a 66 GTO?
I have a TH350 in my 66 GTO 389. Works great, but shifter is ugly. Has anyone tried putting a 67 auto console into a 66? Would it work? I could try for a Hurst his-n-hers while I'm at it.
GRRRRRRRR |
A 67 console should bolt right in where the 66 console was secured. The shifter should bolt in also in the same location . The 66 and 67 i believe shared the same floor pan year to year.
Scott If you always do what you always did You always get what you always got |
GRRRRRRRR |
When I put a turbo 400 in a '66 GTO, I swapped in a whole '67 console with the Hurst dual gate. It works fine & my Son still has this car. What many people don't know is that the '66 console shifter will work fine with a three speed automatic. They were used that way in the Grand Prix. You have to push the little button down to get the stick to go back into first gear.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald |
For 65-66 console you have to cut the hole bigger on top to use a hurst
It has everything, harness too. I am not using it so will let it go. You can sell yours if it is in good shape, why cut up a good console..JMO I am five minutes from Woodbury Commons.
Ant 1967 Pontiac Tempest, GTO-Inspired "What's so special about having Italian food cooked by a bunch of friggin Mexicans" Paulie- Rocky Balboa "Your heart is free, have the courage to follow it" Braveheart http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg Last edited by YVEYANT; 06-06-2008 at 03:15 PM. |
GRRRRRRRR |
I drove my 66 with the original two speed shifter hooked up to the TH350 for about a year. The handle had enough room to get to the three forward gears but the detents only provide for two stops. (I had a reverse shift tranny just to make things more complicated). The only way I could get it to work was to disable the detent mechanism at the shifter. It took a pretty light touch to feel the tranny click into gear... something I don't have, hahah.
GRRRRRRRR |
I don't like to accumulate too much stuff. Let me know when you want to come up.
Ant 1967 Pontiac Tempest, GTO-Inspired "What's so special about having Italian food cooked by a bunch of friggin Mexicans" Paulie- Rocky Balboa "Your heart is free, have the courage to follow it" Braveheart http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg |
Norm
GRRRRRRRR |
