Braswell 4150-4500 base
For those of you with a Dominator intake and want to use a 4150 Braswell makes an adapter baseplate so you don't have to swap intakes! One less variable in testing.
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
I made my own out of 2 1/2" pieaces of aluminum.So basicly it ends up being a 1" spacer.The bottom one bolts to the Dominator intake with recessed allen bolts and the top one bolts to the bottom one the same.Screw you studs in the top piece and bolt on your 4150 carb.Kind of slick.
I should sell the things. |
