Have settled on either a comp 282S or a crower 60310. Would appreciate any thoughts on which one would suit my application better.
68 firebird coupe 455 + .030 6x-8 mildly ported( clean up bowls and unshroud chamber ) milled for about 9.5:1 zero deck block cast iron stock manifold quadrajet 3.23 gears. Turbo 400 Any thoughts appreciated, also torque convertor suggestions with this combo. Thanks |
Ultradyne 280/288 solid www.bulletcams.com, continental "Hand" converter, light pistons and forged rods if you haven't done the short block.
68 Firebird Are you running with the wind or breaking it? |
If you only had those to choose from, I recommend the Crower #60310. The 112 LSA will give a little better vacuum and spread your power band across the rpm range. Do a search on Motordaddy, he has this cam in a 400.
Converter, depends on your budget: High end go either ATI or Continental or Middle ground go with Redneck. You will want a good 3200-3500 rpm. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! ![]() |
the 282 comp is a great cam, i cant see you having a bad choice either way. i bought a redneck converter, it works great.
1970 firebird, 468, e heads, |
I am running the 282S in a very similar engine as yours. It is a great street cam. You can lash it between .015 and .030. At .025 lash the idle is like a 60916, very smooth and I am pulling 18" of vacuum. At .020 you will get a nice lope and about 15" of vacuum. Cam has lots of low and mid range punch to it. Have no experience with the crower solid but the 282s is a great cam for my street only car.
Greg Williams, Wabasha, Mn. 65 GTO, 455, DCI ported 6x heads, Isky Rpm 300 cam, 2-4's, 4 speed, 3.31 |
