A while back there were a few of you that were going to try one of these.......success ?.....failure ?...... good, bad ???
thanks
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
OK...........no one uses one of these ?
If not, what are you using ? Locker, Limited slip (auburn-eaton), mini spool, spool ..... Building a rear end.....looking for the best street/strip setup that will last and work at the track.. thanks
I have one in my 9 inch, Can't notice it all in normal driving, and it seems to hook better then my mini spool. Although that doesn't say much since my car doesn't hook at all with the crappy tires on it now.
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
Mine works great and is very consistent 1.64 60ft and street driven everywhere. I will never buy another brand again.
