Eos discontinued
As of yesterday,6-27-07, eos is no longer available thru gm.What ever the dealerships have in stock is it.Dealerships can no longer order it.
Vernon |
According to GM Parts Direct, it shows 1052367 as being discontinued. It does, however, have an asterisk after the PN. The bottom of the page reads:
"* This part has been replaced by a new part number. The new part number will be used if you add this part to your cart." It doesn't yet show the new PN though. |
I work at a gm dealership.My parts manager got a e-mail yesterday from gm saying they were discontinuing it.
Vernon |
I don't doubt that 1052367 has been discontinued!
GM Parts Direct shows the same, and (even though it could be incorrect) it shows that another PN has superseded the now-old 1052367 PN. Just pointing out that it may not be gone forever. |
I hope so too.Have to wait and see what happens.
The death of the flat tappet cam and the rise of the roller cam will soon be complete
Try using 992869. That's the Canadian part number for AC/DC EOS.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
Looks like we'll all just have to keep a set of old stock springs lying around for break in. My buddy just built a 455 with E-heads and a Lunati flat tappet solid cam, we took out the inner springs and he drove it around for two days (about 100 miles) then put the inners back in, so far so good... I think the cam manufacturers will step up and make something available for the product they produce for break in periods otherwise they will lose millions $$$. IMO I don't think the flat tappet cam will go anywhere too fast, it'll maybe get phased out eventually but no time soon, too many racing sanctions still requiring their use. Thanks D. Miles
Going TurboCharged! |
I bought out my dealer and ordered another case of 12 on Tuesday.
I have heard that the supplemental PN has no where near as much Zinc, which was the whole point.
Matt 1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor 1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD 1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring| 1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners 2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD 2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles |
1052367 has been disc. Will cancel upon order.
No replacement # pending yet. 992869 is not an active part #...at least not here.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
Bty, i have 8 on hand.
Starting bid begins at $12.00 each plus shpg...
I spent some time yesterday looking at oils on the shelf at a local store. The Resolute brand of 10W-30 and 30W, sold by Fleet Farm, is rated SL, which does contain zinc. Resolute is manufactured by US Oil in Wisconsin. Most name brands were rated SM, including Mobil I, and they do not contain zinc.
According to John Sawruck, a former Pontiac engineer and active Pontiac hobbyist, SL rated oils should be OK for our old flat-tappet Pontiacs without supplements.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
All is not lost...yet
You can still order it here online, I just ordered some myself...
http://www.sdparts.com/product/10523...6ozBottle.aspx
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
I stopped using EOS a long time ago. I have been using this for years now to break in cams AND add to oil! It has one of the highest Zinc contents available!! And ALL of there oil has MPZ (this additive) in it!! I am telling you all this is the way to go.
http://torcousa.com/products/product...9-2c0fb1b194a5 Be Cool, Ace
Am I glad I got out of the business I was in? HELL YEAH!!! |
I went to my local chebby dealer today to try to buy some.... No stock!! The parts guy said local engine and prototype shops have bought him out, he was selling 3-4 cases at a time. One of the shop's pressed him on the matter and he contacted GM and he was told the product is on backorder until sometime in August, it is being reformulated to get rid of a harmful chemical! Gee I wonder what that is I went to autozone and bought some STP. Probably just a matter of time before the zink is out of that.
It's a good thing I had sense to buy 20 gallons of Rotella 15w-40 and 50 bottles of EOS last year when I started hearing alot of talk about cam failures. With 3 old Pontiacs it should keep me going for a while.
I confirmed the discontinuance of EOS with the local Chevy parts guy as well, and bought the last ten bottles they had. A POSITIVE SIDE NOTE!! I found old stock of Rotella 15W-40 at a Sams club. Seem like they didn't rotate their stock and if you dig, maybe you too can find the old cases. The old cases don't have as much yellow on the outside and the only thing that is yellow is the "Shell" emblem itself. Good hunting - Bill -
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
GM also has a product called "camshaft and lifter prelube". comes in a small bottle...about 3 oz..part # is 992704. Has a high zinc content. We always keep it on the shelf and the price is cheaper than EOS.
cHRIS |
