65 am fm radio wiring colors ?
am i correct in the following
yellow's power green front speaker brown rear speaker blue accessory control and yes i know i need a service manual, it's on the list. the wiring diagrams are pretty poor for accessories in the 60's cars. thanks, mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
wiring diagrams The Old Car Manual Project
They are available at www.tocmp.com
You have brown & blue confused. I believe that the mile long blue goes to the rear speaker. Brown is the feed for all the accessories for certain.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
as was i jeff, i was trying to save a bit of time laying under the dash, upside down with a shifter cable jabbing me in the back. the service manual sucks in regards to wiring these old car's accessories. i have an a-body manual and it shows the power feed only. solid green was definitely front speaker, black with green tracer are speaker wires, exiting the second plug in the harness. blue appears to be an accessory control as it exits the radio in a separate plug on the opposite side as the power /speaker wires. it has a red connector, if that's significant. i've not traced the brown down yet. thanks for the replies, mike
i got lucky and robbed the yellow power connector from a parts car that i picked up for the 2spd trans. mike
I will check tomorrow, but I think the wire with the connector clipped to the side of the radio is used to power the reverb.
Have you had teh carpet out ofthe car yet? Sounds like there could be a reverb harness there (3 wire ribbon & blue)
bruce, no i haven't pulled the carpet yet. from memory, there's no sign of a reverb unit in the trunk. i'll have to look again tho.
mike
