Trim tag/Data plate help!
The trim tag/Data plate on my 70 GTO looks like this:
.......BODY BY FISHER...8.. ST70 24237...B805090 BDY TR...258...........63 63 PNT ....02B.......B.....0806....... Anyone knows what the 8 above BDY, the B and 0806 on last line stands for? On the buildsheet is says in field #24 (DP SEQ. NO) 805090 85 0806. Could the last 0806 be the same as on the tag/plate? On PHS papers it says date shipped 02-12-70, can this be right? How many days took it to build a car? Håkan Last edited by hakansan; 02-18-2007 at 07:11 PM. |
On the last line, the 02B means it was assembled February, 2nd week, so it's a match. It took one day to assemble a vehicle. And the 0806 on the build sheet and the trim tag should match although not all plants used the same trim tag formats. As to the 8 at the top, no clue. Same with the B at the bottom.
Thanks HFR, any clue what 0806 means? And the 85 on the buildsheet.(805090 85 0806) Only one day to assemble a car?!?! Are You sure? I´ve heard several days and up to 2 weeks. 02B 70 starts with monday 9:th so the 12:th is only 4 days after. By the way, do You know if, and where.. the EUN was on the buildsheet?
Håkan |
If the EUN was found on the build sheet, it would have been handwritten, I believe. No clue on the 85. If this was a Fremont build sheet, the 0806 would have represented this was to be the 806th car assembled for that day. But, I don't know if it's true for the other plants.
