#181
TH 400
Looking for a TH 400 to rebuild? Have some back seats from a 64 tempest.
Craig |
#182
I am looking for a decent set of stock rear lower control arms for a 68-72 A Body. Anyone have some collecting dust? I have a sway bar I want to mount, so I will be sending them to a local welding shop to box.
Thanks! |
#183
Free Mid 70's oil pans
GONE
Two free mid 70's oil pans, must pick up in western burbs of Chicago. Used dirty condition. Cleaning out Garage Last edited by form74; 11-18-2006 at 06:18 PM. |
#184
FREE '69 #45 heads
Got a set of '69 #45 heads in the Denver, CO. area. I've got them on craigslist currently for $60 (both), but they're Free to Pontiac folk on PY. Pick-up only.
http://denver.craigslist.org/pts/238350656.html Drop me a PM or e-mail me at info@ramairperformance.com if interested. Seee-ya, Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor * Engine alive and kickin' March 2nd, '06 * RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers * QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi * Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+' |
#185
EGR's and & Original Bottom Core Support Hardware from 74 Formula
Title says it all, thought somebody might want original Hardware. EGR's from 74/75's and Core Support hardware from 74 formula.
Pick it up or Shipping shouldn't be more than a couple of dollars. Have at least one bracket and bolt for the EGR's |
#186
I have 2 bucket seats from a 70 Lemans. Frames and tracks are in good shape The seat upholstrey is in driver condition and are brown. I also 8 stock used 350 piston standard bore. The pistons I can send but the rest is pick up only from West Michigan area-49088.
Going as fast as I can afford on a fading middle class income. Last edited by LeMans70Sport; 12-18-2006 at 11:49 AM. |
#187
Needing some 68' Firebird Items
I'm looking for a right and left side seat support / seat frame for a 68 Firebird. The ones I have a pretty rusty, and had to cut them out. This is the brace/support that is right on top of the floor pan where the seat connects.
I have several extra items for a 68' I'll offer up if I can find these. Also...........Needing a decent shape glove box door and a valance (which goes between front window and rear of hood). Mine is pretty pitted. Let me know on any of these....I'll look over my items, and offer up a few of them. Phil
Musician / 77 Formula / 68 Firebird Owner http://www.Grasstowne.com http://www.UnclePhilOnline.com |
#188
70 400 Block (.030 over) with "N" crank - some rust
Pistons and rods for same 2nd Gen F Body 10 bolt 2.73 open complete assy I set of 6X-8 heads Assorted other F Body parts including shifter and cable, seat belt interlock, air cleaner housing etc. All pickup only near DC Need 4 cheap steel wheels and tires that hold air to remove racing tires for winter storage |
#189
Hi, Is the air cleaner housing for a TA shaker? I need just the bottom part of the air cleaner for my daughters 77 TA. We have the scoop, just not the part that holds the air filter.
Thanks, David |
#190
No. It is a plain 400-4V from about 74
#191
Scruggs, do you think the 400 will need to be bored more than .040? I dont have any steelies around, only wheel I have with no purpose is a 60/70s style aluminum slot, but it has a tire and air and youre welcome to it. A buddy of mine might have something...you need all for? I will check it out.
Rich
"Artificial intelligence is no match for natural stupidity." |
#192
.040 will PROBABLY be enough. I can't say for sure. I do need four wheels but you are welcome to the block regardless. If you want to come by and see lt let me know.
#193
Block goes to metal recycler Friday
#194
In need of 15 inch (or larger) wheels. Upgraded to discs without a plan for the wheels, surely someone can help me out. Thanks in advance. not looking for handout, have a little $
#195
Dscruggs, you have a pm.
#196
hi rich
hi scruggs happy new year -mike
is this thing on? |
#197
Complete Big Car BOP TH400 - Was running fine when pulled.
2nd Gen F Body 10 bolt 2.73 open complete assy I set of 6X-4 heads, Assorted other F Body parts including shifter and cable, air cleaner housing etc. Need a set of BBC rocker Studs, ARP connecting rod bolts, Decent Q-Jet core. All pickup only near DC |
#198
Thanks, David T. |
#199
Motor mounts, FREE to good home
Brand: Anchor (Korea)
Part#: 2335 (R), 2336 (L) I got em' at checkerautoparts for $7.79 each when I had a hair brained idea that I could move my new 462 back in my '67 by using these mounts. They are just sitting around collecting dust and I am sure someone could use them. New owner to pay shipping. PM me if interested. This is what Checker's web page say's the mounts will fit; 1970 - 1971 GTO 1973 GTO 1970 LEMANS 1972 - 1974 LEMANS 1969 - 1979 FIREBIRD 1970 - 1973 GRAND PRIX 1973 - 1975 GRAND AM 1971 - 1972 BONNEVILLE, GRANDVILLE 1971 - 1978 CATALINA, GRAND SAFARI
The demon code prevents me from declining a rock-off challenge...........we are the D, we are the D, we are the D!!! Last edited by mashedfinger67; 02-11-2007 at 02:58 PM. |
#200
I'll take 'em
