Old 01-07-2007, 08:00 PM
Held for Ransom's Avatar
Default 74 Firebird seat belts
The rear seat belts on the drivers side must have broke and were replaced. I'm looking for a set and need to know the numbers (these are for black seat belts). Here is what I have now
Irvin belts
Driver side, front, 9697033, Model 2416
Driver side, front, female end, stamped mfg by Robbins
Passenger side, front, 9697032, Model 2416
Passenger side, front, female end, stamped mfg by Robbins
Driver side, rear, 9660409, Model 2358
Passenger side, rear, 9660408, Model 2358
Passenger side, rear, female end, 9660408, Model 2358, stamped mfg by Robbins
Thanks.
Old 01-13-2007, 03:07 PM
Formula 400 74's Avatar
Formula 400 74 Formula 400 74 is offline
My 74 AK1 belts are Irvin too, and the female ends are stamped mfg by Irvin.
The driver side rear numbers are 9696823 model 2358. The passenger side labels are the same. I assume they're original to the car, doesn't look like any were replaced.
Hope that helps,
Greg
Old 01-13-2007, 04:16 PM
I pulled the bad seat belt assy. out last weekend and found out that it should be the original to my car but end is bad. Female end is a Superior Ind. replacement (08 93). Are yours black? And, I did post an ad in the parts wanted section.
Old 01-13-2007, 07:02 PM
Mine are red, but the male end doesn't look like that. I'll have to get some photos up tomorrow; all I have right now are of the passenger front female end.
Greg
Old 01-15-2007, 10:57 PM
DScruggs's Avatar
DScruggs DScruggs is offline
I have gutted my car for bracket racing. I have belts available. I will look tomorrow.
Old 01-20-2007, 12:37 AM
Dscruggs, great. If they're for sale, please reply to my post here... http://forums.maxperformanceinc.com/...d.php?t=505411 If you have numbers different than mine, I'm sure others wouldn't mind you posting them here. I believe the front belts were different later on in the '74 run (seat belt warning system box changed).
Old 01-20-2007, 07:41 AM
DScruggs's Avatar
I have the seat belt warning box as well.
Old 01-20-2007, 09:16 PM
DScruggs's Avatar
Here is what I have.
Some Irvin, Some Robbins
DSFM, 9729695, Model 2486, Code AGA73, Stamped "Service Replacement Part.
DSFF, stamped mfg by Robbins
PSFM, 1699808, Model 2514, Code 18A75, Irvin (I wrote down a "1", it could have been a "9", I will check next trip outside.
PSFF, stamped iii and imprinted IRVIN in the plastic
DSRM, 9660409, Model 2358, Code 9A74
PSRF. 9660409, Model 2358, Irvin
PSRM, 9660408, Model 2358, Code 23A74, Irvin
PSRF, 9660408, Model 2358
