Disk Brakes.4 Piston To 2 Piston
Do any of you guys know whats it take to go from 4 to 2 pistons? on a 68. Are spindles different, caliper brackets? sheilds? Any input is greatly welcome thanks.
68 GTO Pure Stock Drags 13.38 106 MPH 2006 |
To what 2 piston calipers are you referring?
I think he means single pistons??? and the mounting brackets are different.
4 piston's
If you are switching to the floating calipers and single pistons, I would be interested in the 4 piston set up.
Email me... james@crossroadspaper.com
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict 68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars) 70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI |
Sorry guys I meant simgle piston. I want to convert from 68 style brakes to 69 style. The car is a 68 gto with factory disk brakes. Do you guys know what I need?
I made the switch from my 68 F-body. I imagine it's the same for yours.
The spindles are the same. The caliper brackets, dust shields are different as well as the end brake line & clip. I was able to re-use the rotors as well (4 piston rotors work on single, but not vice versa). |
not To Hijack your post, but are the guys running the factory 4-piston setup having alot of problems with them? i've heard they have a seal leakage problem? any other issues?
I,am and that,s why I.m changing mine out. Had them rebuilt twice in six years.
Seals
Did you have them bored and sleeved with stainless sleeves?
That is the only way to go then use Silicone Brake Fluid in the car.
My 4 piston ones leaked on our 68 bonni wagon, but put on rebuilt ones and no more leaks yet. I was told that inactivity was the problem with them but our wagon moves everyday so I think we are safe.
69-72 A and 71-74 X body cars are a direct swap.
I could'nt find any used caliper mounting brackets around here, so i bought the brkts from cpucarparts.com Just remove the original mntg brkts and dust shield(i dont use-it holds heat). Install the 68-72 brkt along with same year's caliper, hoses, and rotors.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
