Can someone decode this data plate please. It's on an 80 Formula.
80 04B 2FS87L146372 19B 19L 19U W A51 B36036162 Thanks
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
Doug, the car was built the second week in April. Black paint, Black custom interior. Built in Van Nuys.
__________________________________________________ ________________________ My 79 400 4 speed Formula either get busy living or get busy dying |
Thanks David. Is there a way to find out what other options that came with the car, like rear end, suspention and the like?
Build sheet or Pontiac Historical Services are your best two options. As a formula, you could pick and choose what options you wanted. All came with the performance package 4-Wheel disc if you had the turbo motor. I don't remember what size the rear sway bar was supposed to be, but I believe it was the larger one.
Did they come with snowflake wheels? Saw an 80 Formula on another website and it had the same wheels that are on this car. Can you identify them.
Those are aftermarket rims. Snowflakes would show up on the build sheet or invoice you can get from PHS. Peace of mind is well worth the $.
We may be through with the past, but the past ain't through with us. |
You probably have the original build sheet still in the car. Remove the rear seat bottoms by pushing them in and then lift up. Remove the two bottom bolts and tilt the bottom of the seat out and reach in behind. The original build sheet is always stuffed in the springs. Have removed four of them from different parts cars.
Crusin in the Great White North! |
