hi guys
i just received my oil pump from summit,the box says M-54D-S, but the tag attached to one of the bolts on the bottom plate says M54D. this would be the wrong pump considering i wanted the 60lb pump? the M54D is a 40lb pump? would this be correct? has anyone else had this problem? also does anyone have a part number for hardened oil pump drive? melling catalog list 2 dis-54 and dis-54a. my local part supplier price list only has 54a, and at about $15.00 canadian it just seems to cheep to be the harden shaft. thanks mark
Mark |
hi guys
Mark |
Mark, You got the right part. M54DS=W/pick-up screen, M54D= w/out screen. The hardened shaft p/n is DIS-54A, I think I paid about $10.00 or so (U.S,). Ace @ Pacific Performance Racing has them, his # is 310-832-4596. Hope this helps.
[This message has been edited by Guy Mazza (edited 01-05-2001).] |
...yet just another reason why I prefer used oil pumps over new ones.
Used oil pumps; you know what the oil pressure should be at engine cold and hot. Thus, a new motor's healty is readily assessed. Other new vs old comparisons are just knowns vs unknowns.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
thanks Guy
I thoutht the m54d was a different pump(lower pressure). guess i can disassemble,clean and check. thanks for the info. 1/2 inch i dont think i want to reuse the old had a main bearing bad, may have sucked up some pieces. never had 60 psi anyway maybe this one will. thanks mark
Mark |
