How much nitrous can you get by with, using a 2500 B&M stall that dose NOT have ballooning plates. Car weights 3120 w/o driver.
eheads 292 compcam forged pistions. ![]() |
That's really hard to pin down. Even with the lighter weight, I'd still have the heavy duty convertor to handle the nitrous. I guess how much nitrous you're applying will also make a difference. Here's my experience:
"Generic" 2500 rpm convertor with a 150-HP plate shot and over 4000 lbs. race weight. The best back-to-back passes N/A and N2O were a 12.86 @ 106 (N/A) and 11.91 @ 115 (150-HP shot spraying from launch). The convertor lasted 8 nitrous passes. On the 9th pass it let go at the top of second gear. ![]()
If it's the Holeshot series of converter, you should be safe with 150-175 h.p. worth of nitrous. If it's the Torkmaster series, forget about it. Buy a better converter. In fact, B&M just recently released their "Nitrous Holeshot" converters, which have the anti-ballooning plates built in, and are really decently priced. They're available in all the standard Holeshot stall speeds; 2,400, 3,000, and 3,600.
"My car would be fast if it had an engine, transmission, and rear axle in it."
"Q: What's better than winning a gold medal in the Special Olympics? A: Not being retarded." |
