I have a 12 bolt in my '67 GTO and I keep tearing up the outer bearing on the bearing kit. Anybody else have this problem? I found out one thing from Strange though, the kit I have that most people install is reccomended for drag race use only. The bearings aren't designed to handle any side loading (street/strip use). They do however offer a kit complete with axles and bearings that are a Timken bearing which are readily available at parts houses; which the other style bearings are Strange only. Imight have answered my own question! I just haven't heard of any one else with this problem.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
check and make sure the housing is straight i have seen alot of bent 12 bolts .tube bends and loads the bearing.
------------------ pure pontiacpowerd 86 grand am
pure pontiacpowerd 86 grand am 455 eheads solid flat tappet cam 8;95 @152 HOFFMAN RACING |
Whats the best way to check to see if the tubes are bent?
Try an alignment rack - the orientation of the rear tires/wheels should give a clue
You are correct that most of the C Clip eliminator kits use a bearing that is not real happy with side loads, I think a ball bearing type. Some have a "Oval track" kit or weld on ends that use a taper bearing that handles side loads better.
