How easy is it to repair surface cracks and deep cuts in the endura bumper? I am considering restoring a used one instead of buying new. Is this wise? Or am I throwing good money after bad?
I can do all things through Christ, which strengthens me.. |
Not any new ones. They do have fiberglass replacements. You can use several different products as long as they are flexible materials. I use SEM Weld on mine. It's a two part rubber filler that can fill large areas. Easy to sand and fast drying.
GoatDr |
There have been several threads on endura repair. Search the archives for bumper repair. I fixed mine myself and it looks great.
From a teaching perspective, its probably a good technique for the class to learn - most modern bumpers are repaired in the same way. Bob Trimpe
68 GTO ragtop 91 T/A 69 XKE |
Here's a great site with a good article regarding endura rapair.
http://goatsgarage.com/bumpfrm1.html Regards,
Larry Metzger Columbus, NJ 1968 GTO Verdoro Green Hardtop 1969 GTO Palladium Silver Hardtop 1969 Judge Carousel Red Hardtop X 2 Someday We'll Look Back On This And It Will All Seem Funny. From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973 |
Use the SEM flexible bumper filler, then coat with SEM flexible primer-put lots of light coats.
I recently repaired two LARGE gouges in a '71 endura bumper. Both "chunks" were still attached, but barely.
I used 3M stuctural adhesive to reattach the chunks (let them set up over night under compression using C-clamps with flat wood pieces), finished them using 3M 2-part flexible body filler. Am VERY pleased with the results, the end result cannot be determined with primer applied. Do the search on this forum, I got advice on these specific products from someone here. |
