This is a very compact and much cleaner set-up for those of us running manual brakes.
1. From what vehicle did this Master Cylinder come from and is it 4 wheel disc or, a Disc/Drum set-up? 2. What do I need to do to swap this master for my orignal manual master? http://www.carcraft.com/featuredvehi...58/index.html# |
Check in the suspension/brakes forum for one of my post on this subject. Probably back a few weeks. I was told to install pre-91 caprice master and proportioning valve from late second gen F-body I think, have to re-visit thread myself.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Thanks torqjunki. I'll dig.
Hey torqjunki.......or anybody, Could you folks go to the link above and then click on the photo of the engine and tell me what vehicle that MasterCylinder came from ?
I use an S-10 manual master and proportioning valve on my 76 GP. Stops fine and straight from 125 to 0. This package fit very well with minimum amount of cussing.
fasteddy
fasteddy |
I believe that it is a mopar style master cylinder. Go to www.summitracing.com and put in part number WIL-260-4894. This is the wilwood part.
Chad Dammen ND's fastest Pontiac (I think) and Minot's fastest street car (not like that means much)
3500lb 10.5" tire. 5.34@134.4 with a poor 60' |
Agree with Chad that it looks like an aluminum MOPAR unit. Tom V.
