Is a Nova shroud the same as the GTO? (new to this model!) I've found a supplier of Nova parts that has one for a 68-74 Nova. My car has A/C. Any help is appreciated.
No, the Nova shroud is not the same. I found that out when I swapped my 400 into a Nova. The Pontiac ended up offset to the passenger side, so a full size fan won't fit. I found a Ventura shroud, and now a factory Pontiac clutch fan fits. The shroud is offset to the right like the motor. I'll try to post a photo so you can see the difference. Good luck with your project.
By the way--the photo shows the shroud upside down. In the car, the opening is on the right side.
Thanks for the info! Any ideas on where to find one? The shroud and radiator are the only parts missing (car only has 48,974 miles on it and was stored for 20 years!)
