#61
Actually I was quite impressed with the tire. Ran them at the NSCA season opener in Belle Rose La. The only Nostalgia Super Stock car with street tires, full exhaust, stock suspension and full interior. My car weighs in at 3820bs with me in the seat. On the ET Street my normal 60ft's were in the 1.49-1.52 range at this track with the ET Radial it dropped to a 1.47 avg with a 1.45 being best of the day. This was running 18lbs of pressure on a 8 1/2 rim. Required a couple of real heavy burnouts at first to get them to bite then just a hazing in first into second then pulling out of the water box. Will have more results after the Atlanta NSCA race in a couple weeks. Engine out of the car now getting a few upgrades.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
#62
I'm no model of consistency as I run a M-22 four speed on a street car and have only had about 10 passes on the track in my car. The M/T Drag Radial helped me get my 60 foot from 2.05 to 1.84, with mid 12's for the 1320. Sticky a$$ tire for sure
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
#63
I put the MTDR's on the car and drove it tonight. I hit a back road and did a quick launch or two. If they hook on the track like they do on the street I'll be grinning the whole time.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
#64
wow they look good under the car. both the firebird and lemans. im stuffin them under a 71 grand prix and i have plenty of wheel well. i put my buddies 28-11.5 under there today and it looked awesome. im test fitting a 295/65 tonight. ill try to post a pic if possible. thanks - scott
71 grand prix SJ 4280# 462 new for 2008 - 8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way! |
#65
Lookin' good there, Chris!
It appears that you went with the same setup as I now have on my Formula, 275/60's on 15x8 4.5" BS Rally II's.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#66
Close, Lloyd. Those are 275/50's. I went with the shorter tire to give me a bit more grunt due to the stock 3.08 gears.
#67
Cool.
I'll snap a couple of pics of mine, IF I can get the rear suspension back down near where it should be that is. My new Moser 12 bolt 3.42, new Eaton springs and new brakes are finally done, and the car sits way higher than it used to, prolly 2 inches. Hoping that maybe that the spring eye and shackle bushings need to be loosened and then re-tightened with tht suspension loaded!
#68
okay....I can't let you guys "one-up" me, i need a pair for the '79, the BFG have had it!
where do I find the best deal on a pair?
Home of WFO Hyperformance Shaker induction. |
#69
Crazy as this will sound, I found the best deal at my local speed shop. They beat Summit (sorry, Scott) by $2.00 and I didn't pay shipping. Worth a call.
#70
hmmm......hey Chris....you coming down for PSN?
How about playing UPS?
#71
No, not this year. I have the Nationa F-body Event in Memphis the week before and tht weekend our club is doing another Poncho Power Tour.
We normally do the PPT in the fall but we're switching to a spring run due to other commitments in the fall so May got pretty jammed up for me. Sorry.
#72
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by critter:
No, not this year. I have the Nationa F-body Event in Memphis the week before and tht weekend our club is doing another Poncho Power Tour. We normally do the PPT in the fall but we're switching to a spring run due to other commitments in the fall so May got pretty jammed up for me. Sorry. </div></BLOCKQUOTE> Gonna miss ya, Chris. Hoping we could maybe have a 2 out of 3 grudge match, since our cars are fairly evenly matched! The suspension settled a little, so I'm not quite so embarassed to show a few pics. Here's the first one . . .
#73
and a closer shot of the LR tire . . .
#74
right rear close-up view . . .
#75
Final boring pic for today.
The Moser 12 bolt install went well. Gears are quiet, Eaton posi is tight but quiet as well - no chattering on turns. Used 80W90 dino oil with one bottle of GM posi additive - per Moser's instructions. 3.42 US Gear R&P and 33 spline axles. One thing I've certainly noticed is how much flatter my car corners now. No huge surprise since I finally welded on a replacement RH upper rear sway bar strut bracket. The car now has a 13/16" rear bar on it for the first time since I've owned it!
#76
Nice pictures and Tires I can wait to see a set mounted in person... Id kill for your ground clearance Lloyd...
#77
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 77TA:
Nice pictures and Tires I can wait to see a set mounted in person... Id kill for your ground clearance Lloyd... </div></BLOCKQUOTE> I suppose you're talking about the exhaust system - a trade off between my beloved stock look and performance. I'll wager the car would pick up 0.3 - 0.4 seconds and 3 or 4 MPH in the 1/4 with a true dual setup. Hoping the new Tom Hand / PYPES system will do that AND keep the OEM look! I do want the car to sit level though - like this old pic from the 2003 PSN's!
