How much can be milled off a set of eheads? I know that you can .060 but is it possible to go more?
I went .075 on my 463 drag engine with no problem. I have heard you can go up to .100".
Just watch out for valve to piston clearance if you have a big cam.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
I knew a guy who had .125 cut off some low compression heads by a speed shop.
The head gaskets leaked like a sieve, pushrod geometry was all screwed up, and the bolts all needed washers as most bottomed out in the block. Tom V.
How much more do you need to go ??
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I was hoping to go .075.
I have #16 heads [ 1968 ] that have been milled 0.110". I also had the intake face milled the same amount so that the intake alignment remained the same. With dished pistons, I have a CR of 10.2:1 & am using Felpro # 8518 head gaskets. I bent the mating edge of the valley cover to seal properly, the edge that seals along the bottom of the heads below the intake ports, because milling that face leaves a step that can be hard to seal. My cam has a reduced base circle, so valve tip/rocker tip relationship was perfect. I should add that these #16 heads were exceptionally clean & rust free in the coolant passages. I wouldn't have attempted that big a cut on badly rusted heads.
