Old 06-01-2004, 07:41 AM
"Guy
Send a message via MSN to
Can I safely use the stock 68 unbaffled oil pan with around 375 rwhp? At what 1/4 mile time does the pick-up become uncovered?
Thanks.
"Guy
Thanks.
Old 06-01-2004, 08:39 AM
burch burch is offline
I wouldn't use a stock pan on any race application.
The problem will show up under braking at the top of the track before it shows up under acceleration. With a stock pan it's amazingly easy to starve the motor for oil.
Old 06-01-2004, 10:02 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
un"baffled pan" and PRO LONG oil additive will go together!!!
do not reuse that,as is pontiac engine oil control design is poor ,use everything you can to help by adding baffel,windage tray,scrapper, and a good oil pump, like PONTIAC DUDE says in his engine assembly tips....
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 06-01-2004, 11:25 AM
"Guy
Just got off the phone with Jeff Kauffman. Intresting....He said run a scraper with either stock windage tray, no baffle in the pan or no windage tray,baffled pan. He uses the later in his builds. Should be good either way as he put it. Hard braking being slight problem but he didn't think so. Horsepower gains would be a toss up for the two combo.
