Hi guys,
I bought a 69 Lemans w/ sprint engine, the car is in junk situation. According to deal w/ Junkyard owner he will give me a 350cui pontiac engine and TH350 installed on back of it. Next summer I ll start to work on the car but before starting I need some tricks - code numbers for choosing the good Pontiac engine. Sprint engine is a strange engine, but its 6cyl. does it worth to built it? (I dont thin so but just want to be sure) Thanks. Burak. |
Hi guys,
As difficult as it is to get an OHC-6 Sprint engine rebuilt here in the USA,and your in Turkey I would go with a 350 or better yet a 400 engine.
I'll dig up some 1969 350 numbers for you when I find my book.I have 2 1969 LeMans you can view in my Profile if you want to? Are you wanting a 1969 motor that would have been in a '69 LeMans or you just looking for good engine for your car? GTO.....Gran Turismo Omologato,True Pontiac Excitement!
GTO.....Gran Turismo Omologato,True Pontiac Excitement! |
Just so you know (before you modify this car):
74 cars - LeMans Sprint two-door post coupe 378 cars - LeMans Sprint two-door hardtop 7 cars - LeMans Sprint four-door hardtop 48 cars - LeMans Sprint convertible Glenn Uettwiller http://home.earthlink.net/~birdman8/index.html Only the visionary who sees the invisible can achieve the impossible. |
Thanks for the replies,
It seems like its impossible to find a 69 lemans engine here, there are a few and they are mostly in mint condition, I have only chance to find a good 350 pontiac engine ( 400cui engines are hard to find too) . Since I ll swap to a 350cui the car will not be a numbers matching car anymore, I ll make a street strip car with rollcage, autometer cauges, racing harnesses etc. My plan is: getting a pontiac engine , totally rebuild it w/ forged pistons and rods, prepare for the "juice" ... thats why Im looking for good/strong pontiac engine, I need codes/suffix numbers of engine blocks... Is there any pages showing this codes? |
wallace racing will have the info you're wanting.
tuned properly that sprint 6 will surprise you with it's performance and milage. too bad parts are tough to find. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
I'd stick with the 6, or at least be careful not to modify the car in a way that can't easily be returned to it's original state. The OHC 6 is a neat engine and an unusual combination to see these days.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
You are right, Overheadcam is really strange engine for 1969, Im really confused about keeping the sprint or not. On the other hand car is not running, rusty rolling chasis, all parts stuffed in side. It will vacuum $$$ from my wallet if I try to restore it to original appearance. I ll keep the original parts in garage, but built the car as a street/strip car, I ll recondition the upholstery and install to the car but I ll put racing seats and harness, autometer gauges.
After this ı can search for the right parts to restore, then I can start. My other ride is a 74 z28/lt, looks like a street car but its 420hp , I want Lemans looks wild ( I plan to paint it non gloss black). By the way thanks for the link, I ll check it now. Thanks. Burak |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by mike nixon:
. tuned properly that sprint 6 will surprise you with it's performance and milage. too bad parts are tough to find. mike<HR></BLOCKQUOTE> Mike, you are right, ı checked the specs of it, allmost same hp level with SBC s Parts are really PITA here ıts impossible to find part for a sprint engine here... I have to buy then from US. I did the same thing for my Camaro before. |
But it's also becoming difficult to procure 350 engine parts, I think. I've heard that the piston supply is drying up, so the only logical Pontiac V8 choice is the 400.
Before you make any more decisions or spend any more time and money, check out the Overhead Cam Six Forums: http://pub83.ezboard.com/bsohcsix Glenn Uettwiller http://home.earthlink.net/~birdman8/index.html Only the visionary who sees the invisible can achieve the impossible. |
Here are some 1969 350 engine codes to look for if your wanting to stay some what close to factory specifications for the 1969 models.
350 engine: 2-bbl carb 265 HP Manual transmission WC WP WM WU Automatic transmissions XL YJ XR YN XB YE UY XS 350 engine: 4-bbl carb 325 HP Manual transmission WK WN Automatic transmissions XC XD 350 engine: 4-bbl carb 330 HP Manual transmission WR WV Automatic transmission XT XU YP GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Thanks for the responses,
I ll swap the inline 6 , but I ll keep it to rebuild, its really interesting engine. When it comes to V8 issue, I will check the junkyards inventory, if they have a 400cui, I ll go for it, other wise go with a 350. Infact junkyard owner doesnt have idea about if sprint engine worth or not I take the V8 engine as compensating the cars being 6cyl Thanks for the code numbers. |
If you do find a 350 or 400 engine there will be a date casting on the block by the distributor hole and a part number on the back side of the engine,there is also the engine code on the front of the block,passenger side just below where the head sits flush on the block.
There will also be a date casting on the intake and on the side of the heads,and a code casted on the center exhaust port of the heads.Get this information and post it if you need any of the engines checked before you choose one. GTO.....Gran Turismo Omologato,True Pontiac Excitement!
I would realy appreciate your help, thanks a lot.
Hopefully this sunday I can get the castings, then you can check for me. that was exactly the thing I wanna do *On my L82 SCB, I swapped to 461 camelhumps, cc ed them + used steel shim 0.015" and had CR 10.72:1. Im looking for a similar trick again As far as I learn from the other posts in here stock pontiac 400 or 350 crank can handle nos applications, also short rods too is that correct? Also, what is the stock material in the pistons? forged steel or cast iron? Im a real rookie on Pontiac, isnt it |
