I have a 70 bird..... what year spoilers will interchange with this car...... i have seen the one piece and the 3 piece
thanks |
thanks |
I never heard of a one piece unless you are talkin 69 T/A or a 70 Z-28 spoiler.
70-81 will fit. All Centers are the same. the changes are in the end pieces. 70-73 would be correct 74-78 are so close 99% of people will never know. The diff between them and a 70-73 is the point by the tail light.. 70-73 comes even with the bottom of the tail light and has a square corner. 74-78 extends slightly past the tail light and has a more rounded corner. See Pic here of the 74-78 spoiler on my 70 Bird I have a 70-73 set here in my office but no camera handy to show ya. 79-81 don't taper as they round over the quarter pannel.. they stay full width down to the body line. GURU: One who knows more jargon than you Scott Schering 70 Firebird 455 12.34 @ 108.2 Http://www.pontiacs.org
William's Law-- There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance. Scott Schering Http://www.pontiacs.org |
I seems Like the camaro ones a realy different..... except the center piece they do not seem flush either is this correct
Camaros run two types of rear spoiler. The one piece - which is the smaller of the two and bolts to the trunk lid and hangs over the tops of the rear quarters by 6" or 7"on each side. The other is the three piece spoiler which uses the same centre section as a Firebird spoiler, but has different end pieces. These end pieces are not a direct fit to a Firebird...they would need to be modified if you wanted to run them as the bodylines are different.
Regards, Leigh 1976 Trans Am 1970 RS/SS Camaro Sydney, Australia
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
