Old 03-16-2005, 12:31 PM
Morty Morty is offline
I have a friend with an 81 TA that has a Chevy 305 and a manual tranny. He wants to take my old Pontiac 350 and throw it in his. What would it take to mate that up with his tranny? And what else would he need to get the job done?
Old 03-16-2005, 04:04 PM
The trans wont be any problem. He will need a Pontiac bellhousing and flywheel. He is also going to need Pontiac motor mounts, exhaust manifolds, accessory mounting brackets. Posibly a Pontiac clutch bell crank,clutch fork and adjuster rod.
Old 03-16-2005, 06:52 PM
I'm not familiar with the older manuals. So you can buy a whole different bellhousing? Where would you get something like that? What type of trannys were put in older Ponchos?
Old 03-17-2005, 10:19 AM
dfektive4's Avatar
dfektive4 dfektive4 is offline
The tranny will bolt up only a BOP bellhousing pattern will be needed. It should have a Borg warner Super T-10 in it now.
Old 03-17-2005, 02:20 PM
Go to the parts wanted section of the forum and place a request. Also try flea markets.
Old 03-21-2005, 11:52 AM
dfektive4's Avatar
If he is going to need acc brackets i would be willing to do some trading for the 305 brackets, if he is interested.
