Old 07-12-2005, 02:50 PM
69 work in progress 69 work in progress is offline
Can someone help me identify the engine in a 69 that I just bought? The casting id is YE. Casting numbers on the front of the block are D738797. Any help is greatly appreciated.
Old 07-12-2005, 03:05 PM
Try Here.
Might need the date code and the block code to know for sure.
Old 07-18-2005, 09:22 PM
jim69bird jim69bird is offline
From my pontiac service manual..
YE is the code for 350, 265 HP, Automatic, 9.2:1 compression ratio 9777254 cam, 1111942 dist, HD Valve springs small valve cylinder heads.
My guess would be that your heads are 47. I have an XB block in mine, with the same specs.
Old 07-18-2005, 09:41 PM
The block code does not make sense.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">D738797 </div></BLOCKQUOTE>
I show it to be casting 9790079
The block casting number is behind cylinder 8 on the passenger side.
The date code for the block should be near the Distributor mounting pad. You will probably have t remove the distributor to read it.
It is a letter (Month, A = January) followed by the day (1 to 31) and year (0-9)
Old 07-18-2005, 09:47 PM
try this site.
http://www.wallaceracing.com/enginesearch4.htm
Old 08-03-2005, 04:19 PM
tjdjr's Avatar
tjdjr tjdjr is offline
sounds to me like you have a 68-69 400 assuming the number is 9790071 not 9790079. I have the 9790071 YE code in my FB. Date coded for 68
