Back-drive linkage questions
Never really looked that closely at the automatic versions of these before......and it appear they evolved slightly......over the years.....
The bell that holds cross shaft to frame.....had a mounting bolt tab to support a vacuum line clip........which I am assuming ended in 73 or 74.....
I have several of the cross shafts with a bent lever.....which I am assuming was done by off-roading......or for header clearance.....or were there different cross shafts
for TH400 vs TH 350?
Any input is appreciated
