Old 05-02-2024, 11:58 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Default What heat range for 118 fuel?
I ended up picking up a barrel of 118 leaded fuel, non oxygenated, nothing else was available. 14:1 517 Ia2 380 High Port heads. I know I probably don't need that much , but didn't have much to choose from and wanted to make sure i have enough for the year and I got a pretty good deal on it.
Previous combo at 13:1 was a 7 plug and trying to decide what heat range would be best. High Ports are now 64 cc and 14:1.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 05-02-2024, 01:16 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
what fuel were you running before? Im at about 14:1 hi ports 540 and had run a 7 on e85, tried an 8 on c10 and then went to an autolight -10 equivalent on a recommendation, and wont go back down but thats on 110/112 octane. I beleive my plugs were glowing at 7500 and causing some issues that went away with the colder plug
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 05-02-2024, 01:17 PM
when I was 13:1 was using 110
6.27@107
9.97@131
Old 05-02-2024, 02:32 PM
steve25 steve25 is offline
Even with that level of compression that 118 will cost you some power if your trying to scratch out every last drop of Hp.
Old 05-02-2024, 09:50 PM
Matt1970gto Matt1970gto is offline
We have 8s in all three cars. I made a few runs with 10s in my motor but had other issues & switched back to the 8s. 571 c.i. around 15 compression on my motor , dads is 565 same compression & my sisters is a mild 535 build.
Old 05-03-2024, 04:37 PM
blueghoast's Avatar
I would try mixing the 118 with premium pump gas maybe half and half.
my 462 @11:5:1 made 13 HP from 110 to 91-93 pump gas I was flabergasted.
Went from 625 to almost 640 should be very noticeable increase. JM2cnts.
trq. didn't change much at all.
GT
Old 05-03-2024, 05:15 PM
In 2020 when I had dad’s motor on the dyno I tried two fuels both from VP. X14 & 14+ we picked up about 8hp with the x14 over the 14+ but lost 13 ft lbs of torque. Last summer I used renegade 120 (what the engine had & had originally dynoed with ) & fuel factory f14. My first pull I used my engine builders fuel & carb which was a 1450 braswell. Second pull my 1250 get’m & the f14 and I picked up 11hp. Then we started tweaking and playing to get more numbers
Old 05-04-2024, 02:36 AM
Dragncar Dragncar is offline
You can mix 3 gallons of 93 with 7 gallons of 118 and end up with a little over 110 octane.
Old 05-04-2024, 07:19 AM
Mix ratio chart.
Old 05-04-2024, 10:19 AM
Octane Mix Chart
Old 05-04-2024, 12:23 PM
http://www.wallaceracing.com/octane-mix-calc.php
Thread Tools
Display Modes
