Old 04-28-2024, 12:15 PM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
Default Removing rust stains
What product/method is good for removing rust stains from painted surfaces? Have a few spots in the door jambs where these rust stains won't wash off.
1963 Catalina 2 door hardtop
1968 Catalina 2 door sedan
Old 04-28-2024, 01:19 PM
VCho455's Avatar
VCho455 VCho455 is offline
We used to use Ospho, on the boats and barges, at work to remove rust stains back in the day. Like the rust streaks seen in the vertical white strip on the side of the barge. It worked well but got outlawed.
It may affect the shine on automotive paint so test it someplace hidden first. You can try diluting it too. Which we used to do when removing rust from vinyl logos on the equipment.
Old 04-29-2024, 09:39 AM
78w72 78w72 is online now
What is the rust from? if its coming from underneath the paint, you cant really remove the stains as they are not just a surface type stain.
There are products for stains, Ive used one called "the must for rust", its a phosphoric acid liquid that you apply & leave on for 15-20 minutes & it chemically removes the rust, works on stains and heavier surface rust. There are others like rid-rust or even CLR that works on calcium/lime or rust stains.
Need to determine what the rust is from, a product might help or remove your stains but if its happening under the paint it will come back & eventually break through the paint.
Old 04-29-2024, 03:27 PM
63 Pontiac's Avatar
I think it's from a bolt head or washer, definitely not under the paint. I'm going to try the CLR and see what happens.
Old 04-29-2024, 04:23 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Get an aerosol can of Gibbs penetrating oil. It is mazing. STOPS rust and removes stains. I use it every year on any natural finishes on my cars. Guaranteed to work. I had to order my cans. No one sold it locally. GOOD STUFF.
"Bill"!
Thread Tools
Display Modes
