Water Pump Going South?
hi, all,
made this video last October while checking my hideaway install that captured a high pitched knocking I've heard before while under the hood. you can hear it clearly around the 5 sec mark. is this the water pump? https://www.dropbox.com/scl/fi/xxp9i...ruqyekyzo&dl=0 appreciate the ears, mike MA Last edited by RAIIIJudge; 04-15-2024 at 09:04 AM. |
Run it with the belts off and see if what you are hearing goes away.
Clay |
I have not watched the vid, but I have heard such sounds if you have a auto trans and the flexplate is cracked to one degree or another.
If you have a clutch fan also check that the fan itself does not wobble on its shaft.
4spd , no clutch fan
thanks, fellas |
Thread Tools | |
Display Modes | |
