Need 4 spd info
Looking at 3, I believe to be, 64 Muncie 4 spds. One has no groove, one has one groove, and one has two grooves on the input shaft. Hopefully, someone can help me identify, or lead in a right direction!!!
THANKS "Bill"! |
Bill, here is a link from 5speeds.com :https://www.5speeds.com/casting.html
Paul Cangualosi is very good on these. As he has stated in his book and his videos, due to the age of Muncie transmissions, sometimes it’s better to look at the casting numbers vs looking at input shafts due to previous rebuild and mixing/matching of parts. He has a lot of good informational videos on YouTube as well. Good luck |
Seems like the 64 units had a smaller diameter countershaft - shaft hole bore is smaller in the front of the case.
Something about them is said to be slightly inferior , I think that was it . |
The case should help with the year, the last three digits are as follows
1963 case number 704 corvettes only as far as I have seen 1963 and very early 64 had case number 606 very rare case used in corvettes, never seen in a GTO by me, but 64 corvettes got them 64 case number 325 with pat pending very early cars before Jan 64 64-65 case number 325 with pat number 66-67 case number 010 68-69 case number 660 70-74 case number 661 always pop covers as even replacement Muncie input gears had no grooves Muncie close ratio heavy duty (m22) had no grooves on production line, but no heavy duty 63-65 m22 build (save for a very few rare road race corvette) many 63-65 have no grooves, this is why you have to pop side cover Muncie close ratio (m21) had one groove Muncie wide ratio (m20) had two grooves 66 and newer M20 and M21 are not exclusive to the Muncie as this is the GM RPO code and Saginaw used this as well (Camaros and non SS Chevelles and other GM's that used both cases use The M20 wide ratio and M21 close ratio for Muncie and Saginaw cases) |
The Following User Says Thank You to Sunfirered64 For This Useful Post: | ||
Sunfire
Mr. Sunfirered64,
If you have a Sunfire Red ‘64, would you care to post some photos. Thank you.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
I'm not Sunfirered 64, but we have a Sunfire Red 64 and here are some pictures.
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO |
The Following 2 Users Say Thank You to Rich-Tripower For This Useful Post: | ||
And just for fun, a few pictures from "back in the day" (early 1970s) and one of the alpha and the omega (we own both).
The Following User Says Thank You to Rich-Tripower For This Useful Post: | ||
It is in my trailer and in project state as we we just moved a couple of months ago. The house we bought shop is very small, so we will be building a new building here shortly. Then I can start to work on it again.
Chevy style muncies have the speedo fitting on the passenger side. Pontiacs have it on the driver side of the tailshaft housing.
Also the above comment was correct; the early units have a smaller countershaft; the later ones are 1" and better. George
The speedo is mostly true, but the early ones all had the speedo on the drivers side up to the 010 trans 66 model year and then all had the passenger side once they went to the 661 case with the 26 spline input and 32 spline output.
Hope this helps. I didn't note the source
The Following User Says Thank You to GtoFM For This Useful Post: | ||
Thread Tools | |
Display Modes | |
