Old 01-15-2024, 01:25 PM
Mario64's Avatar
Mario64 Mario64 is offline
Default heater vacuum valve on 1964 a/c/ car
good morning:
this is for my 1964 389 grand prix with air.
my valve is leaking. it opens but does not close 100%. see below pict. i am guessing i need one that is normally closed until vacuum is applied. then it opens when there is a demand for heat. anybody have a good replacement part number or manufacturer. or one to sell?
thank you.
mario64
Name:	water valve.jpg
Old 01-15-2024, 03:13 PM
Yellow Banana's Avatar
Yellow Banana Yellow Banana is offline
I found the heater control valve for my 64 GP a/c at Parts Geek it is a Four Seasons part no. 74606. Mine performs perfectly.
Old 01-15-2024, 07:22 PM
Mario64's Avatar
Thanks for that. Now all I need to do is remove this stuck one! Any hints from anybody?
Ciao,
Mario64
Old 01-16-2024, 10:19 AM
mgarblik mgarblik is offline
Ciao,
Mario64
Yes. Once you have a new one in hand and your sure it's correct. Cut the old one off just above the nut. Then use a 6 point impact socket and a long 1/2" drive ratchet or breaker bar to remove. Should come right out.
Old 01-16-2024, 12:28 PM
Mario64's Avatar
mgarblik:
thank you for that wonderful tip. the intake is off so if there is a problem, at least i wont have to pull the intake.....lol
mario64
Old 01-18-2024, 09:09 PM
Mario64's Avatar
Thanks again. It worked like magic. I notice that there is a restrictor in the threaded part of the nipple. Looks to be 1/4 inch hole. One half the diameter of the threaded nipple, approximately 1/2 inch.
Mario64
Old 01-18-2024, 09:34 PM
Glad it worked out. Was not aware of the valves having a restriction, but it makes sense. To keep a surge of water from damaging it when the thermostat opens. They do that to protect the heater core as well.
Thread Tools
Display Modes
