Coil Placement
In I'm in the process of installing an Edelbrock Pro Flo 4 system and I am looking to place/install the coil. There aren't any spots on the back of the intake for the bracket to bolt to, however, it bolts to the back of the head nicely. Would this be an issue for heat soak?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. |
That’s perfectly fine to mount it there.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Believe some Pontiacs came from the factory with the coil mounted that way.
The Following User Says Thank You to John Milner For This Useful Post: | ||
Thank you, Gents.
...but I'd absolutely move the fuel pressure regulator so it's not directly in line with the flywheel/flexplate. Then put the hoses inside the frame rail so they're somewhat protected from an explosion.
I use the PF4 also and placed my coil there. why did you not use the rail mounted vacuum reference regulator designed for the pf4?
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
The Following User Says Thank You to gassman_67 For This Useful Post: | ||
This was the regulator suggested and provided by my fuel tank provider, Tanks Inc.
My 1964 A-body V8 cars all came from the factory with the ignition coil mounted to the back of the passenger side cylinder head.
The Following User Says Thank You to b-man For This Useful Post: | ||
Thread Tools | |
Display Modes | |
