Old 03-18-2023, 10:02 AM
lrust's Avatar
lrust lrust is offline
Default Using Points Distributor with non-factory wiring harness?
Anyone have a suggestion on how to safely wire and set up the reduced (<12V) voltage level needed for a points set up when I only have 12V available? Factory wiring harness is not available in the car and I want to use the points system to run a points compatible tach. Thx.
Old 03-18-2023, 10:42 AM
242177P's Avatar
242177P 242177P is offline
Easy. You use an "old school" ballast resistor. I know MSD has them.
Old 03-18-2023, 11:18 AM
lrust's Avatar
well - I figured there was an easy answer. Thank you! I was going to get the abacus out and do some engineering calculations but that might have resulted in a car fire.
The Following 2 Users Say Thank You to lrust For This Useful Post:
Old 03-18-2023, 11:26 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
The original points wire harness had a full 12V to the coil during cranking to give a little more juice for starting a cold engine. If you have a hard starting problem a separate 12V wire from the ignition switch to the coil might be needed.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 03-18-2023, 11:35 AM
242177P's Avatar
The R terminal on the starter solenoid was designed for that.
Old 03-18-2023, 03:12 PM
Kenth's Avatar
Kenth Kenth is offline
Or you may use the SMP RU11 resistor. It has .50 - .60 ohms at start and 1.75 Ohm while driving. No extra wire from starter needed.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-18-2023, 06:09 PM
I've always used a Mopar resistor with good luck. Use the early style. The later ones are a double resistor. You can usually get one at any good parts store for cheap money.
Thread Tools
Display Modes
