Old 12-20-2015, 11:05 PM
racerboy's Avatar
racerboy racerboy is offline
Default 15" Rally II on 1970
Hi everyone. I was thinking about pulling the original JT wheels off my Judge and just keeping them for shows and that sort of thing, and picking up a set of 15" Rally II wheels. I see they are available in the aftermarket in 15x7 and 15x8 and 15x10. I think the 10" wheel would be too big, but would you go with a 7" or 8" wheel? Would there be any clearance issues?
Sent from my iPad using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 12-21-2015, 05:48 PM
pggto's Avatar
pggto pggto is offline
I would think you would be fine with the 7" or 8" wheel. I've run 15x7's on my 70 for many years with a 245/60/15 tire. I don't think the 8" wheel would be a bad idea either just depends what size tire you want to run. If you going to run a 70 series tire stick with the 7" but if you want to run a 60 series tire you could go with the 8" wheel as well. Just make sure the back spacing is proportionate to the 7". I think the 7 is 4.5 or 4.75, I would need to double check to be sure.
Old 12-21-2015, 06:34 PM
goatless's Avatar
goatless goatless is offline
Unless you're gonna go with something really big for tires, I'd stay with 15x7- then you can use factory wheels- a lot cheaper than getting new repros.
Here's a picture of my T-37 (when it belonged to b-man) with 15X7 Rallys and 245/60/15 on the front and 275/60/15 on the rear. Plenty of room all around. '70-'72 have huge wheel wells.
1966 GTO
Old 12-22-2015, 03:59 PM
racerboy's Avatar
thanks guys! I saw an ad on eBay for a set of 15x6 Rally IIs. I didn't even know they made that size wheel, but I will look for the 15x7.
Old 12-22-2015, 07:44 PM
Ram4king's Avatar
Ram4king Ram4king is offline
I have 3 sets of 15x7 rally complete with tires and a set of 15x6 if your interested and I'm in Philly
Old 12-24-2015, 11:05 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Exclamation
15X6 Rally IIs were big car only. Bolt circle is incorrect (5") for an A, F or G-body.
Regards,
"455HO" Lloyd
Old 12-24-2015, 01:03 PM
steve v's Avatar
steve v steve v is offline
I thought the 77-79 Catalina & Bonneville Rally II's were 15" x 6" with a 4 3/4" bolt circle. We pulled a set off of a 78 Cat at a local LKQ last year for next to nothing.
Old 12-24-2015, 01:35 PM
goatless's Avatar
My son has a '77 Bonnie with the 5" bolt circle.
Also, I believe they did make a 15X6 Rally II with the 4 3/4" bolt circle.
1966 GTO
Old 12-24-2015, 10:41 PM
Jack Peters's Avatar
Most '70's G body rally's were 15X7. Same bolt pattern.
JLP
Old 12-25-2015, 03:31 AM
The 15X6 inch rim is a std. rim for use on all cars. The 15X7's were for the performance cars, & were the optional rim. Didn't get 15X8 until you got the T/A with the 8" snowflakes. No 15X8 inch Ralley II's unless made that way by the aftermarket.
Old 12-25-2015, 04:45 AM
cuz68's Avatar
cuz68 cuz68 is offline
Not all rims clear the disk brakes.
Cuz68
Old 12-27-2015, 03:15 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i found a set on a late (77-78) standard firebird that were 15x6.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 12-28-2015, 12:09 AM
post toastie's Avatar
I have aftermarket rallies with a 4 inch backspace which kinda limits tire sizes.
Stock rallies were 4.25 back space. on the first pic and last are pontiac 15x7 ralies the two middle4 inch backspace pics are aftermarket 15x9 and 15x7 with
4 inch backspace.
Name:	428 tri powers 001.jpg
ID:	416725   Click image for larger version
Name:	428 tri powers 008.jpg
ID:	416726   Click image for larger version
Name:	428 tri powers 007.jpg
ID:	416727   Click image for larger version
Old 12-28-2015, 12:32 AM
I have a few 15x6 rallies with 4 3/4 bolt pattern
Thread Tools
Display Modes
