New CV-1 Combo - Dyno Results
Hi Guys,
I haven’t posted here much lately and thought real hard about not posting this. But, against my better judgment, because of how CV-1 threads normally go, I decided to go ahead and post anyway. I know, aside from the few guys that seem to bash CV-1’s every chance they get, there are a lot of other guys that would be interested in this info. So, here we go. But, first of all, a big THANKS goes out to Calvin Hill and Jim Sammons for all their help, couldn’t have done it without them. Anyway, I finally finished up my new CV-1 combo, so here it is. Now, first of all, this was NOT a max effort, all out, heads-up class build, not even close. I’m just a bracket racer and it had been about 6 years since I had done anything other then general maintenance to my engine, so it was time. I went into this as just a simple freshen up and in the process, upgrading my existing KRE Hi-port top end to CV-1’s. I had no horsepower goal in mind, although I was hoping for about 75-100hp over my old combo. Of course, this isn’t meant to be any kind of apples to apples head comparison, so don’t take it as that. I’m just showing my old and new combo and what horsepower I gained from the swap, it’s up to you to do what you want with this info. Now, my original combo, as you can see most of this in my sig, was an aluminum IA2 block, 525ci (4.310 X 4.500), forged crank, GRP aluminum rods and Ross pistons, all from Butler. Compression was 14:1 with KRE Hi-ports (standard pushrod location), and a BOP intake, both heads and intake ported by Dan Barton, with the heads flowing 388cfm, BOP belt drive and a 1250 dominator on alcohol. The cam was a Comp cam 4-7 swap with .471 lobe lift and 285/288 duration at .050 on a 110 centerline and running 1.65 rockers. This combo dyno’d at 822hp @ 6800rpm and 719tq @ 5500rpm. For the new combo we had to go to a 4.325 bore to clean it up, same 4.500 stroke crank, which makes it a 529ci. The rods were due to be replaced, but I stuck with the GRP rods and went with Diamond pistons. I had to go with a slight dome (about .060) on the pistons to keep the compression at 14:1, because of the slightly bigger combustion chambers of the CV-1 heads. The heads are Calvin Hill’s Fusion port 435cfm versions, and Rolands cast tunnel ram. Had to replace the cam also, because the old one was showing some flaking on a couple of the lobes. But, I stuck with the Comp cam and a .471 lobe lift. The duration is now 285/300 at .050, 114 centerline and a standard Pontiac firing order, No 4-7 swap. Still on alcohol with the same carb and headers. Now to the dyno, with turned out much better then I anticipated. The last pull we made, which was also the best, ended at 974hp @ 7300rpm, 760ftlbs. tq @ 6000rpm with the timing set at 34. We played with the timing everywhere from 25 to 36, and 34 is where it like it. We initially degreed the cam in on the stand and never played with cam timing on the dyno. That’s an increase of more then 150hp with basically just a top end swap. We could have kept going and gotten a little more out of it, but I was more then happy with that and it was getting late, so we called it good. As I said, this is just a bracket combo and I wasn’t worried about trying to get every last ounce of power out of it. Again, this is NOT intended to be an apples to apples head comparison, so don’t take it as that. I’ll be more then happy to answer any and all questions about this combo, but if this thread starts going south like all the other CV-1 threads, then I’m out. Kelvin
'70 Trans Am, full tube chassis, 2360 lbs., IAII Aluminum 529ci, CV-1 Heads - N/A - Best 1/8 mile 5.10 @ 133 mph, Best 1/4 mile 8.08 @ 165, Best 60ft. 1.120 - (SOLD) 2009 Norwalk KRE Quick 16 Winner!!! '61 Tempest wagon 2Dr, '05 GTO LS2 powered, 12.39 @ 109 mph at Drag week 2015 - https://www.youtube.com/watch?v=jsVRzMXERtA '64 Grand Prix, Pump gas, 529ci., CV-1 Heads, Holley Dominator EFI. - Single turbo in progress.. '70 Trans Am, Ram Air III 400 - 4 speed. |
congrats Kelvin.. Always look forward to seeing your car in action. Good luck with the new bullet
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
Great job Kelvin! Sounds like a great Pontiac combo there.
Good luck, Tom Syron |
Congrats Kelvin, I'm looking forward to seeing good results in the car.
Congrats Kelvin!
That is awesome and your car should really like it. Pontiac Power To The Front!
Good job man! Congrats and thanks for posting.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Congrats on a well thought out build. Look forward to hearing some track results.
Congrats Kelvin. Cars gonna fly
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
That's great Kelvin!! Congrats! Can you post some pics of the engine?
Brian
Boobs & bacon |
Thanks for the update. Let us know when its in the car and you make some passes. Good job.
Great job Kelvin, and from one Kansan to another, I'm glad you posted the info, at some point I really need to get my ass over to your shop and introduce myself.
Stan |
Nice combo
A few questions. You say tunnel ram. So it has 2x4 now?? What size headers? What size lifters? What rocker ratio? Seems like a big RPM spread between peaks Thanks
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Great results, thanks for sharing your combo!
Congrats and kick A$$ next year! |
Thanks for posting, Kelvin...Glad you did....be interesting to see how your chassis is gonna like another 150hp. Keep us posted on the results!
CONGRATS! looking FORWARD to track results!
Nice numbers Kelvin. Last time I saw you run you were knocking them dead at Norwalk going rounds.
Who's this Calvin dude?? Just kidding. Good work.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 10-19-2014 at 10:12 PM. |
Thanks for all the kind words guys, I appreciate it. The bad thing about just now getting the engine done, is the season is now over here at my local tracks. But, Tulsa races thru the middle of November. So, I'm gonna get it back in the car and try to get down there before the season is completely over.
This is the only pic I have of the engine right now, I'll post some other ones tomorrow.
As always Kelvin, glad to see a friend make some great power, no matter where it come from. Looks like you have a big dog for next season's racing.
The dry sump will be a good addition on your program. Say hello to Jim Brady and Mark Schottler for me. Tom Vaught So where are you going to race at next year?
The headers are 2 1/8". They started as a BBC Headman weld up kit that I built. The Lifters are standard size .842 Pontiac solid roller lifters that Calvin Hill sells. The rocker ratio is 1.85. Thanks for the questions.
I'll make sure to say hello to Jim and Mark for you next time I see them. I plan to race mostly local stuff next year, Topeka and probably Great Bend along with our 1/8 mile track in Manhattan. I am gonna try to make it back to Norwalk next year, though.
Thread Tools | |
Display Modes | |
