1985 Grand Prix with 455 10" TH400 8.5rear
1985 Grand Prix (silver-gray) built for street&strip activity. Been done awhile & runs strong, but this combo never ran the 1/4mile. The car is quick.
Q-JET/Torker-I/HEI/6X-with Ferea valves/455+060/Headers into 3"exhaust system to tails. Electric Fan. New ATI-10" 2800-3200/TH400 (on e of my builds) 3.90:1 posi 8.5"rear, special upper&lower bars Fuel-cell with Holley pump and 1/2" line to engine area. New tires& rims all around. Interior Burgundy & gray. Appears stock, with gauges carefully installed into dash. Street: nothing needed. Strip: Should install: a new driveshaft & safety loop. Also cut-off switch since battery is in trunk. Price: $5000 or interesting trades with cash. |
Nice looking car HIS. What would be your opinion of what the car would run in 1/4?
Low 12's to high/mid 11's.
Still Avail. Willing to reduce price down (perhaps to $3500) with Trade-ins on interesting parts:
Some parts ideas well-ported Iron heads HO Exhaust manifolds, Soft-Ray Rear glass for 70GTO nice endura core for 70GTO NICE set of Rally IIs original to 70 GTO PD TH400 for 70 GTO Iron 4bbl Intake for 68 nice GTO Hood for 68 Ram Air flaps/air filter setup for 68 GTO Gear Vendor OD Tail Kit for TH400 |
Seems like a good deal .
3 potential trades declined for common Reason: I cannot take-on a (total) dis-assembled project now.
68 LeMans Survivor would be nice. Keep those ideas coming. |
Is this a bench or bucket interior car? Any frame work done to the car, reinforcing rear control arm mounts or anything? Do you have any other pictures that you could put up?
Thanks, Troy
'80 Grand Lemans Was 301 C.I. Will be bigger soon. 00 GTP NBM / Graphite, Stock Sold Aug. 2011 70 GTO Black / Black TH400 460 CID, 542 FWHP, 580 FWTQ (Sold, Fall '09) 04 GTO Black / Black M6 Back to bone stock and sold, fall '05. |
It's the Split-Bench, Burgundy cloth.
NO frame work done (don't think it's needed). Proper PMD Motor Mount Brackets. G-Body Crossmember with TH400. Not remembering the Rear suspension features (at work right now). Suppose I make some photos... |
still available. trades for interesting parts or suvivor 68 LeMans entertained.
How is the body? Any rust? Paintquality? Everything else working (HEATER,etc)
Regards |
Has Landau vinyl top over rear passenger roof area, weatherd but all there and carries a good survivor look. Everything else working, except the AC and heater core was removed underhood. Would need heater hoses and heater core to re-attain heat. Needs for Reliable Street: Modern Upper control arms to attain a good castor alignment. Dial-in the engine idle for cold-start idle. hot-idle is fine. Electric fan thermo-switch (have) needs installed for automatic elec fan on/off. Fan turned on manually as-needed (stop lights, hot summer highway). Needs for reliable race: Aftermarket driveshaft to handle the power if slicks are used. Safety loop. Kill switch installed ( have) for battery in trunk requirement. |
Still avail. Turns out the heater core is still in, just needs 2 heater hoses for heat.
Drove it (like i stole it) around the block Sunday. new price after 6 Nov. Last edited by Half-Inch Stud; 10-03-2012 at 07:45 AM. |
Im interested
Would you be interested in a trade? I have a 68 LeMans Convertible roller. Someone had previously made it into a GTO clone. Body and frame are in very nice condition, could use paint. It has a 12 bolt wit 3.73:1 gears also a turbo 400 trans. I live in the area (Pottstown). Thanks, Rich
68 LeMans Convertible GTO clone SOLD |
STILL AVAIL. Post election results so let's make a deal.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
can i get some better pictures. send them to my email jgman005@gmail.com thanks john
photos this weekend, then i will mail them out. Thanks, HIS
Photos sent.
Thread Tools | |
Display Modes | |
