Old 09-26-2010, 03:53 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
Default Dog Dish clips
Well, I bought a set from Fusicks a while back and now I just bought a set off ebay from TAZIMMY. Someone on the forum contacted him and he assured them that they were not the same clips. They are the same clips and they still suck. The barbs still break off and the clips are still damn near impossible to get on.
Save some bucks and order them from Fusicks and get the same crappy product haha
I'm going to take the wheels off, hammer the clips on and then tack weld them in place. Hopefully I don't break any like I did on the last set
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 09-27-2010, 09:50 AM
Engine-Ear's Avatar
Post
Originally Posted by poison heart View Post
set from Fusicks and ... a set off ebay from TAZIMMY. ... They are the same clips ...
I had heard that, too. Makes the few originals I have lying around even more special.
In defense of Fusick, they are an OLDS vendor...they probably work perfectly on an OLDS rim. Just a thought.
Old 09-27-2010, 02:46 PM
Well, the problem I had with them once I finally got them mounted on the rim is when I tried to install the hubcaps 2 or 3 of my clips actually broke. Olds or Pontiac, they should be stronger than that.
We'll see how these go
Robert Lewis
Old 11-26-2010, 09:15 PM
Steves65's Avatar
Steves65 Steves65 is offline
Have you figured a way to use the tazimmy clips? I have a set and so far broke three and have not been able to get any on....They seem brittle.
Old 11-26-2010, 09:20 PM
Engine-Ear's Avatar
Have either of you guys called tazimmy? Maybe he has a suggestion since he is into DarkSiders, too.
Old 11-26-2010, 09:29 PM
Steves65's Avatar
Hey Matt,
Hope you had a nice Thanksgiving......yea that mite be too easy like reading the directions LOL....actually sent him a message and am still waiting.....take care.
Old 11-26-2010, 09:43 PM
So explain to me why you can't run these hubcaps on the newer style rims with the **** stamped into the rim that hold the cap?
former." --Albert Einstein
- Winston Churchill
Old 11-26-2010, 10:44 PM
misterp266's Avatar
That'd be me......I have not tried to install them as I'm no where near having wheels under my car yet. They "looked" good to me but I have never had originals or Fusicks ones so nothing to compare them to. I may just end up with ET five spokes to avoid the whole deal. I want 15 inch wheels too which I need to have made from my centers. If I can't put the caps on when I'm done it may not be worth the effort. I'm interested to hear what Tazzimy has to say....
Rob...
Mike, these caps are smaller and actually fit inside the ridge on the rim, not outside. It's too bad because it makes wheel choice much harder!
" Darksiders Rule "
Old 11-27-2010, 02:35 PM
The newer style wheels have little nubs that stick out that the hubcap snaps over and the little nubs hold the cap on. The early hubcaps have no nubs but have 3 slots in each wheel which a small metal clip slides into and the hubcaps pops over the clips and the clips hold it on. To me the early ones look better because they are more flush with the wheel and don't stick out like the later ones do.
I just recently put the TAzimmy clips on my car. It went smoothly but I have broken a few clips the last time I tried to put them on a car so I kind of figured out how to do it by trial and error.
Take the wheels off, get a hammer and some sort of punch (or something to extend the hammers reach) since it's hard to hammer directly on the clip. Hammer the clip in the slot, make sure it's seated as well as you can get it. Try to make sure it's straight. Tack weld that POS on there, repaint the wheels and pop those dog dishes on there!
TIP! You'll notice that one of the clips is spaced further than the other two. Start the hubcap on that one, then slide it over one of the other clips, and then with a fist you should be able to tap it a few times and get it to slide over the remaining clip. It's easy if you start with the furthest one away
Here is what you end up with
I'll try to remember to take a picture of them tack welded on.
Robert Lewis
Old 11-27-2010, 02:39 PM
Here's a closer pic of the correct style dog dishes on my Catalina.
It might be hard to tell but this is a later style snap on hubcap on a chevy 15" wheel that's on my Star Chief. I'm pretty sure these are Canadian hubcaps, I thought they went well with the Star Chief because they have little stars on them, not quite "correct" but they look sweet
Robert Lewis
Old 11-27-2010, 05:53 PM
stevep's Avatar
stevep stevep is offline
Robert, you are correct, they are Canadian hubcaps.
Old 11-27-2010, 05:55 PM
I'd like to find a nicer set but they're hard to find
If anyone has a set I'll trade them a nice set of 61-64 dog dishes
Robert Lewis
Old 11-28-2010, 11:47 AM
Stu Norman's Avatar
Stu Norman Stu Norman is offline
Canadian or not, they look bitchin'......
Stu Norman
Msgt. (ret)
Hortonville WI
May the torque be with you.
Old 11-28-2010, 04:08 PM
Thanks! I like them better than the regular 65+ caps
Robert Lewis
Old 11-29-2010, 12:08 PM
carmak's Avatar
carmak carmak is offline
Will Pontiac caps fit on a 62 Olds wheels with clips?
Old 11-29-2010, 03:12 PM
Engine-Ear's Avatar
carmak, I think that Olds design vs. the Pontiac design is the difference here.
My spare clips are buried but it'd be helpful to have someone take a good pic of the known-Pontiac clip next to the Fusick / weld-in (ugh) clip.
Old 11-29-2010, 06:40 PM
carmak's Avatar
I remember talking to someone at the POCI convension in the Quad Cities that he had a full set of Olds wheels on his 63 Catalina with poverty caps.
So my thought is that Pontiac clips on a Pontiac wheel hold a Pontiac cap and Olds Clips on an Olds wheel hold a Pontiac Cap but Olds clips on a Pontiac wheel do not work.
Carmak
Old 11-29-2010, 10:16 PM
real61ss's Avatar
real61ss real61ss is offline
Those clips are expensive......I guess I got lucky, I wanted a set of 15" wheels for my '62 Cat and I found a set of 4 on Ebay last summer. I bought the set for $125, when they arrived they were the nicest wheels you could imagine, all of the clips were perfect with no rust at all. I called the guy and ordered one more for the spare and it was nice also. They were sand blasted and painted black. I sent them out and had them powder coated gloss black. Here's the guys Ebay information, you might check to see if he has anymore.
eBay Member: calouisiana [caloui_ku5755ldtg@members.ebay.com] His phone number is 337 852 6824
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
Old 11-30-2010, 05:35 PM
I believe Olds and possibly Buick used the same clips on earlier cars. Fusicks claims like 46?-58? clips are the same as the Pontiac clips.
I've never seen the Buick ones up close but I have seen pics of 1950 Buick clips and they appear to be identical although they used 4 clips instead of 3
Robert Lewis
Old 11-30-2010, 05:36 PM
You can get 15" wheels from early 40s-early 50s Pontiacs which have the clips riveted on
Robert Lewis
Thread Tools
Display Modes
