Old 09-07-2010, 11:45 PM
Glenn Lever's Avatar
Glenn Lever Glenn Lever is offline
Default Front Engine Dragster Update
Body is getting painted (Pontiac Power)
The parts you have missed can be seen here.
http://www.leverfamilysite.com/2010_...gster_Root.htm
ID:	217910   Click image for larger version
ID:	217911   Click image for larger version
ID:	217912   Click image for larger version
Glenn R. Lever
Rochester, New York 14617-2012
Web Site http://www.leverfamilysite.com/
Front Engine Dragsters http://www.frontenginedragsters.org/forum/
Old 09-09-2010, 10:53 PM
It has been awhile since I produced a web page update on my site, so here goes.
There has been progress on a couple of fronts.
I am sitting here waiting from a call from the painter to see If I will be running out to Indiana tomorrow.
If I do not leave tomorrow, I will not be able to leave for Indiana until next Thursday. It will be very tight but on that trip I might be picking up the dragster to bring home. I hope to have it at the Big Dawg Shoot out between the car clubs here in Rochester 09 22 2010.
First up are the mechanical updates.
Shims have been made to space out the nipples of the water pump, why, the engine plate bolts between the water pump and the timing cover. This moves the water pump out so shims had to be made so that the nipples of the water pump engage the timing cover.
On the last trip out to Indiana the engine was brought back to Rochester for detailing. The valve covers need to be stripped and redone, and breathers installed.
Arm rests have been installed on the cage of the cockpit to assist this old man getting in and out of the dragster, also Fire nozzles have been installed in the cockpit area.
The chrome work is back from the chromer.
Tires have been mounted on the rims. As the tires were purchase in Indiana they are of course Hoosiers.
The Body and chassis has been shipped off to Bewley's Garage, 220 Park Drive, Plainfield, Indiana, Carey Bewley is doing the paint work and his e-mail is careybewley@yahoo.com and phone number is (317) 372-2244.
The entire body was sanded, then smoothed, guide coat applied and then block sanded.
Now it is time for the House of Kolor Epoxy Primer/Surfacer.
There have been several attempts at laying out graphics and we are getting close.
I hope to see the finial layout this weekend.
That is the current status of the paint. I will update this page again when there is more to report. That should be very soon.
The link to the page is below
http://www.leverfamilysite.com/2010_...2010_09_09.htm
ID:	218096   Click image for larger version
ID:	218097   Click image for larger version
ID:	218098   Click image for larger version
Glenn R. Lever
Old 09-10-2010, 10:56 AM
Brian Baker's Avatar
Lookin' good. You see my post in the other thread in the "blown" section about your timing cover being a stressed member?
Old 09-10-2010, 11:24 AM
Yes, My thinking is it is only supporting the weight, not the troque stress as there is also a rear plate. I will try it like this, if I have a problem I will make new ones that run for the heads.
Glenn R. Lever
Old 10-06-2010, 10:07 PM
It has been awhile since I posted an update on the progress of the dragster build.
Paint has taken way longer then I ever expected.
First one shows base coats before candy green.
Second one shows three coats of candy
Last one is five with some of the tape pulled off showing some of the white strips.
Gold leaf and pin stripping yet to go.
The dragster should be coming home early November.
Interesting note is the check written as a deposit to start the build was dated 10/30/2009.
It is just possible I might pick it up 10/30/2010
Here is a link to my web site with the last update I have placed there (new to this board). I have not kept it current as the only photos I have are from a cell phone camera. I did supply te painter with a camera and once I have those pictures I will add them to the webd site.
Oh yes, one more thing, current weight estimate is 1,900 pounds. that means 1/4 mile ET is 9.13, way to slow. The build for the blower engine has been put on the fast track. If it is done by spring it may go right into the dragster right away, but as an injected engine, not blown, and then progress to the blown engine.
ID:	220505   Click image for larger version
ID:	220506   Click image for larger version
ID:	220507   Click image for larger version
Glenn R. Lever
Old 10-07-2010, 12:10 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Absolutely beautiful!!! Good luck with it.
Old 10-07-2010, 06:48 AM
60man's Avatar
60man 60man is offline
Looking good....
Progressing to blower is probably a good thing. Time to feel monster out..
ECM member.
MANDRA
Old 10-07-2010, 07:37 AM
Green is my favorite color. Candy green and gold leaf is going to look pretty sweet when it is done. Body shops are funny sometimes when doing a custom paint job and not "bread and butter" repair. My Can Am was in the shop for 19 months when my father had it done.
Old 10-07-2010, 09:14 AM
gene simmons gene simmons is offline
X2 Very nice!
Old 10-26-2010, 11:49 PM
I'm hoping to drive out to Indiana this weekend and pick the car up.
Finial clear coats. Still needs finial wet sand and buff out.
ID:	222445   Click image for larger version
ID:	222446   Click image for larger version
Glenn R. Lever
Old 10-31-2010, 01:39 PM
New body pictures
ID:	222934   Click image for larger version
ID:	222935   Click image for larger version
ID:	222936   Click image for larger version
Glenn R. Lever
Old 10-31-2010, 01:53 PM
goatasaurus rex's Avatar
goatasaurus rex goatasaurus rex is offline
glenn, awsome work. its 1965 again!!!
69 GTO 11:66@114.17 all balls no bottle
406 d-port iron heads 3700lbs all steel
Old 10-31-2010, 02:43 PM
I like it, the dark green is remeniscent of the old Jade Grenade. Cool stuff.
Old 10-31-2010, 03:05 PM
misterp266's Avatar
Reminds me of the Poison Ivy car. Here's a pic I took at the MM a few years back. Car is looking awesome BTW!
" Darksiders Rule "
Old 10-31-2010, 04:51 PM
The poison Ivy car was my inspreation for the paint schem on this car. I did not try and copy it, just the combinations of the colors.
ID:	222943   Click image for larger version
ID:	222945   Click image for larger version
ID:	222946   Click image for larger version
ID:	222947   Click image for larger version
Glenn R. Lever
Old 10-31-2010, 06:29 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Car is looking great Glenn. When will you be getting some test runs?
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 10-31-2010, 07:47 PM
Robert
When I get the engine mounted in the car, wired and plumbed, I will travel as far south as I have to to find an open track
Glenn R. Lever
Old 11-02-2010, 11:55 PM
The pieces are about to start to come together!
The frame is actually a dark green with flake in it.
I cannot tell you how much I am looking forward to getting this piece of art home.
Many people have put long hard flustrating hours of work into this vehicle and I can not express my thanks enough.
ID:	223243   Click image for larger version
ID:	223244   Click image for larger version
Glenn R. Lever
Old 11-24-2010, 10:41 AM
Being assembled for pickup
ID:	225670   Click image for larger version
ID:	225671   Click image for larger version
Glenn R. Lever
Old 11-24-2010, 10:58 AM
Ron H's Avatar
Ron H Ron H is offline
Looks great. Should be alot of fun. Congrats.
68 Firebird
Are you running with the wind or breaking it?
Thread Tools
Display Modes
