# 15 heads ?
I have a good running 1968 400 with # 15 heads. Does anyone know if they are small valve (1.96") heads ?
I have some 350 type 6X heads laying around I can rebuild; thought about making them useful -
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
The #15 heads are small valve but the combustion chambers may be just the right size for a good street compression ratio. CC the chambers, I bet they'll be in the low 80cc range which would be good for about 9.5:1 CR. You can easily have the small valves replaced with big ones at rebuild time (you'd buy new valves anyway, right?) and then you've got a nice set of big valve heads with nice sized chambers. Only other thing you'd have to do would be to pull the pressed studs and tap the holes for screw-ins. Sell the 6X-4s to someone with a 455 because you'd have to mill them quite a bit to get into the lower or mid 9:1 range compression wise.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
The 15's were one year only ('70) 455 heads with 87cc chambers and small valves/press-in studs. Perfect chamber size for streetable comp ratio on a 400 - just change the valves and studs and you'll be in good shape. Save the 6X's for a 455 build unless you plan to add some boost power-adders or want to go with 87 octane on your 400.
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
Hang on to those small chamber 6x heads as they are getting to be hard to come by!
SJM |
1977 Trans Am,400 4 speed,numbers matching car 1979 Bonneville ,1 owner car... 1997 Trans Am convertible,LT1/auto. |
68 #15's
I agree with firebirdcrazy1959, I also have a pair of 68 #15 heads with about a 75cc chamber. They came off of a 68 big car, Small valve press in studs.
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/248@.050 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker. |
1970 #15's [87CC] are a great 455 head,give about 10:1.I have a set on a 400 i just did a stock rebuild on,haven't run it yet.The other set i'm porting and having big valves and screw in studs done to them.
'68 340HP 400 #15's , nice , cheap street/strip head , small valves don't hurt mild combo's , easy mid-low 13's in a very mild 2nd gen F-body setup , good big valve/porting potential when the other heads are too pricey or not available .
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
Thread Tools | |
Display Modes | |
