Ok,
How the hell are the Jim Minos and such getting that fast in the 1/4. I had a 69 Bird with a 462 kinda mild (744) buttload of torque and only 105mph (355's). My dad runs the purestocks regularly (VETTE) and I try to go every year and watch these ponchos run like raped apes and it can't be just suspension and porting. Any input would be cool. Thanks Scott |
Camshaft,tweeked intake and carb, tweek this and that. A lot of tweeking I'd guess.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
Just take an obscene amount of $$$$ and years and years of R&D and its simple
My Daddy bought me a car but all I got was this old Pontiac. |
Scott,the speed in the 1/4 mile is really a ratio of HP to weight.Ets are affected by tires,chassis AND weight and HP.The real diff is they are making more HP than you!My car will run the 1/4 in 111-112 if I start out in first or second.Starting out in second kills the ET.Find more HP and or lighten the car.IMHO.Tom
You do 20 different tweaks that each find 1 or 2 hp. For example, the rear axle housing is tweaked to be perfectly straight (most aren't), all tolerances are checked, and the rear end is set up for minimal friction.
http://www.pontiacpower.org/ |
see 12.0 signature to assess your combo. HIS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
HIS, cking your sig, there is a big difference between a 469 cube with 48's & torquer street/strip early Firebird & a 412 cube (or so) RAII bird running cast iron manifolds & (biggest allowed) G70-14 polyglas tires.
Oops...me not-so-stock. I got fooled by the 462 stuff. Sorry.
Suppose a stroke difference of 4.21" instead of 3.75" could have been all the difference.
Thanks for the replies,
I know some of the fast ones are stroked but some, like Jim Mino and some other GTO's are not. These guys are getting 350+ HP at the tires through exhaust manifolds. You can port manifolds all you want and you'll get nothing more than what, 10 horse? A ram air 2 bird all tweaked out running consistant 12.30s all day long. Unbelieveable! There is Hemis, 454 chevelles running 12.60 to 13.30s, tweaked like mad. But watch a handful of Ponchos kill theses mean, larger cubic inch musclecars. I guess I am jealous because my old bird had headers, 2800 converter, bowl work, etc and 105 mph. No I did not dyno tune this car with o2 sensors but I still find it remarkable that no headers and mild sounding cam can actually make damn near 400rwhp. Oh well, my new ride is a 68 ragtop 4spd Lemans stock. I'm going to make 400 rwhp from a 400 somehow. Any pointers would be greatly appreciated. (no aluminum heads, but will run headers) My current 400 engine is a W72 version from a 77 Trans AM and I going to start building pretty soon with the help from all you nice pontiac people. Thanks again for any input. Scott |
I know when I talked to Mino several years ago he felt the actual Pontiac GM RAIV cam was better than any repro and made some difference.
They always amazed me also as well as the NHRA stockers running 11s with smogger 78 low compression motors. LOTS of tweaking carbs,timing.convertors etc. I saw an article awhile back on a 427 Chevy car and some of the chassis/convertor tweaking to hook up on those old repro stock sized tires.
There is an ad in the Chiefton claiming to get 672 HP out of a 350. e-mail is www.PontiacEngines.com . Phone is 909-370-0389. Its in So. Cal. I dont know anything about the outfit so.... Good Luck
You don't wana go there, or so I've been told.
How about Patrick Wendling's street driven 69 Ram Air IV 400 Firebird-he has run a 11.76 at 118.75 in F.A.S.T with still more Potential--race weight 3,665 lbs .
The Bandit Rules - Make mine with a SD-455 Engine . |
How about the NMRA pure stock class running low to mid 11's in the 120-130 mph range outta them mustangs, a couple of guys have dipped into the high 10's. Talk about tweeked!
Come on down and see a whole new crop of them here:
JULY 30th Englishtown,NJ http://www.musclecarrace.com Wish I could get Jim Mino to come down! Anyone have his email?
http://www.stockappearingdrags.com http://www.stockappearingdrags.com Come on get off that lawn chair and drive that car like it was meant to be driven. 69' 400 RAIV Judge Conv... 12.86@107 Factory Stock 69' 400 RAIV Trans AM .....12.48@110 Factory Stock 69' 400 RAIV Judge HT..... 13.07@104 Factory Stock 73' 455 SD Trans AM........13's?? not run yet 66' 455 GTO Convert.........12.20@112 non original 63' 421 SD Catalina...........restored fast as h*ll |
Edward Farrell, Danger Will Robinson(arms waving) -Jim
if i read the rules right, a raV headed engine would not be allowed in the fast class?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Thread Tools | |
Display Modes | |
