#101
Old 07-19-2021, 11:32 AM
Vid's Avatar
Vid Vid is offline
Very impressive numbers and a beautiful looking motor! My garage door is always open if you get tired of playing with it! LOL
  #102
Old 07-22-2021, 11:04 PM
slowbird's Avatar
slowbird slowbird is offline
Final numbers with the RPM were 600tq starting around 3600rpm, peaking at 640tq around 4500 and peak hp of 608 at 5800rpm
The Following User Says Thank You to slowbird For This Useful Post:
  #103
Old 07-23-2021, 08:33 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Great job! You put that Performer RPM to good use.
Go fast, see Elvis!
  #104
Old 07-23-2021, 12:35 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Wow, great numbers, Was the Performer RPM worked over or just a port match to the head?
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
  #105
Old 07-23-2021, 01:54 PM
slowbird's Avatar
Plenum work and port match
  #106
Old 07-23-2021, 03:54 PM
455dan's Avatar
455dan 455dan is offline
Great numbers,
that 69 GP should really scoot.
Is it an auto or manual car? How is the idle quality and vacuum at idle?
Again, Very Impressive wide band power.
  #107
Old 07-23-2021, 04:17 PM
slowbird's Avatar
Originally Posted by 455dan View Post
Great numbers,
Auto, on the test stand it had around 16" vacuum
  #108
Old 07-24-2021, 03:05 PM
ta man ta man is offline
It should actually get decent mpg..depending on carb tune car weight and gearing.
  #109
Old 07-26-2021, 09:21 AM
TransAm400 TransAm400 is offline
Interesting that its making that much vacuum. I recently got mine running also. Cam duration is almost the same. A little less lift. I'm only reading 8-9" vacuum idling around 800 RPM. Will get it on a chassis dyno after I get some bugs worked out with the EFI.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Thread Tools
Display Modes
