#81
Yeah, the holley smart coils have their' own dwell settings.
Very good, glad it's running! And tuning is the fun part! .
#82
First, thanks for the plug & your setup should be arriving today or so. Regarding the balancers, I've spoken to a few manufactures at PRI about doing such. Same answer from all is demand. While we this there's demand, its not 10,000 or a large enough amount for them to redesign tooling. If an individual/ group were to fund a 1 off run, that is a possibility.
1972 HO Trans Am auto White/white 1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue 1978 Trans am gold/ black ,T56, t tops, EFI 474, Build: http://www.pro-touring.com/showthrea...1978+g+machine 1999 30th Trans Am 6 spd, T top |
#83
Okay so I still think the timing with the dual sync is suspect. I just don’t trust it. I’ve decided to add a crank trigger set-up. I’ll still use the dual sync for the cam sensor. At first I was just going to add a MSD or Moroso 4 magnet set-up with a Hall effect sensor but now I’m thinking a 12-1X set-up couldn’t hurt. It’s basically the same effort between the 4X and 12-1X.
Has anyone tackled this yet? Does MSD sell the Pontiac specific sensor bracket separately? I called Holley and it was a very frustrating conversation… the guy didn’t even know that MSD already made a Pontiac specific 4 magnet kit #8650. They just read a damn script. I’m thinking of adapting their SBC 556-171 kit to my build. Thoughts? https://www.holley.com/products/parts/556-171
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 07-24-2023 at 08:35 PM. |
#84
Does you ATI balancer have the magnets in the outer shell? If not, you can just get the outer shell that has the magnets. They also make a reluctor wheel incorporated into the balance cover. I've always shied away from ATI balancers because they only make 3 bolt pulley balancers for Pontiac.
Innovator West is the only balancer I know that has the magnets built in (as pointed out previously) and they do sell a pickup bracket for Pontiacs. I have no experience with them so can't comment. I believe I mentioned before that there is a late 70s timing cover with no timing marks on it, which would make it easier to mount a pickup bracket. I've read a number of posts by the Holley EFI forums admin that state there's not much benefit of using anything more than a 4x wheel, just to throw that out there. A good way to tell if there's an issue with the current crank sensor is to toss a timing light on it and enable static timing. If the timing reading is jumping around, then you know you have an issue. The problems with the dual sync show up as either crank or cam sensor inconsistent readings, or they don't read/work at all. They are also failure prone. If you are concerned about it, then just replace the distributor entirely. If you have a crank sensor setup already, and are doing DIS/CNP etc, just get a block off type cam sensor and be done with it. My issue is I don't care for the look of mounting 8 coils, and that's the only reason I haven't gone DIS/CNP. I will probably use a pro billet for a cam signal, and to distribute spark via conventional rotor/cap setup. .
#85
I don’t have magnets in my shell. I contacted ATI regarding the 4X or 12X shell on Monday. They answered lots of questions and were very helpful. Replacing my shell with a shell with magnets is $300-$350’ish depending on how many magnets you add. They can also service/rebuild it for $85. They said it would take two weeks total. I strongly considered this because none of the accessory pulleys would need to be adjusted since the shell with magnets is the same width as their standard balancer. This option would’ve gotten pretty pricey with the other items I’d still need added in. I called Holley/MSD and they were zero help. The MSD 8650 is only available in a 4X and they do not sell the kit pieces individually. On the website you can switch out the 8650 4X kit magnetic sensor for a Hall effect sensor for $30 extra… they told me that was a glitch and it wasn’t available in that configuration. https://www.holley.com/products/igni...its/parts/8650 I called Moroso and they don’t make a Pontiac crank trigger kit. They also don’t offer a Hall effect sensor in their kits. Their kits are nice and a lot cheaper than MSD. Plus they are black. I ended up deciding on the Holley 556-171 7-INCH 12-1X CRANK TRIGGER KIT, SBC, HALL EFFECT kit as it was the most cost effective and had the biggest upside. https://www.holley.com/products/parts/556-171 Having the extra resolution of a 12X vs a 4X can’t hurt. The kit already comes with the Hall effect sensor. I think we’ll be able to adapt the SBC kit without much trouble. Bonus points that it isn’t red
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
#86
I'm curious to see how it looks mounted, post pics when done please!
#87
12X crank trigger is in and it’s running amazing! It sounds great and revs super quick for a first/base tune (they used the 496 BCC base map for starters)
Please ignore how dirty it is and the missing spoiler… I’ll put it back on soon as it come back home https://youtu.be/Wg44N5IXbso
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 08-04-2023 at 11:35 PM. |
#88
Holley really needs to work on their quality control!
The brand new Hall effect sensor that came with my 12X kit is dead. It worked up until yesterday under very limited run time. The car was idling yesterday and then just quit and wouldn’t start again. This morning they switched it out for a MSD Hall effect sensor and it fired right up. Then they switched the Holley back in and bam… no starting again. The sensor is bad. It’s pretty disappointing to get a brand new dual sync that was dead on arrival and then a $600 crank trigger set-up with a faulty Hall effect sensor immediately after.
#89
Does anyone want to share their idle settings? I’m working on idle tuning with a large cam. I’d like to see others starting points. I’m currently using the base 496 chebby stuff. It idles around 1200-1300rpm during warmup. Once it’s warm it idles higher and higher. It’s not uncommon for it to start idling at 1700rpm.
Common sense tells me I’m getting too much air in the engine. I’m using a remote IAC. It’s GM screw in style sensor that goes into a Kinsler adapter piece. Any suggestions are appreciated. This could lead to some good tuning discussion
#90
That looks good the way it is, but need to see the parked value.
Also make sure the throttle blade is closed enough too. The IAC is showing 0%, and generally you want to shoot for like 5-10%. Close the plate in like 1/2 or 1/4 increments to try to get that. And of course, make sure the TPS Autoset has been performed properly and recently. Any manual changes to the throttle blade requires a TPS Autoset. 700 RPM might be a little low too for a 'large' cam. I'd probably shoot for around 825-850, or even a little more depending. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#91
Ok, now I remember which TB you're using.
To start out, I suggest just backing the screw out until it bottoms the plate in the throat, and give it like 3/4 of a turn. Do a TPS Autoset, cycle the key, and then look at what your IAC % is, dial it in from there. .
#92
Great install, Did you finally get it running well?
Sent from my Pixel 6 using Tapatalk |
#93
While mingling around at the Good Guys show this past weekend I found a tuner locally that has a hub dyno and I’m kicking around the idea of letting him tune it. I’m going to see how if he has an opening in early May.
Thread Tools | |
Display Modes | |
